Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My oven lights but will not stay hot. says temp is 350 but was just maybe 150 deg inside (touchable). oven temp/thermometer resistance is between 1000-1100 ohms at room temperature. is it the computer? Jgbp35gep2wg
  • thwilson69 Jun 22, 2009
    didnt help. could it be the electric thermostat? Both igniters work.
    Top Expert:
  • GE Master
  • 81,294 Answers
Replace the thermostat probe.
Posted on Jun 16, 2009
Gas owen overcooks
I get this service call a lot so lets verify temp before we discuss possible causes set the rack in the middle of the oven hang an oven thermometer in the center of rack set a 350 let run 1 hour check the temp after an hour this gives the oven enough time to cycle and stabilize this will give you the true average of oven, temp placement of thermometer is important plus or minus 15F on either side of 350 is not that much of a big deal the max range for a temperature offset is usually 30F, there should be a tech sheet in a plastic pouch on the back of the unit now if you do find it to be running 50F too hot well there are test to determine if the temperature sensor is operating correctly it should read appx. 1654 ohms at 350 this tells the control board to open the heat relay stopping power to the gas valve lot of work you have to have the oven out back panel off to access the wiring going to control unplug machine at 350 disconnect wiring from board to ohm out sensor, sensors go bad and so do boards, sensor is cheaper try changing it first.
Apr 04, 2015 | Maytag Kitchen Ranges
Why is a Kenmore elec range model 665.92004102 have oven temp lower by 100 deg at settings of 400, 450, 475 and 495; while off 150 at 350 deg setting?
There is a problem with the oven probe sensor or EOC. To ensure this problem is fixed both parts would need to be replaced. This could cost more then $300 to have repaired.
Apr 23, 2014 | Kenmore 95822 / 95824 / 95829 Electric...
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Dec 30, 2008 | Maytag CWE4800A Electric Single Oven
Re: oven
the temp probe ( rod sticking out of rear wall inside oven ) should ohm out at 12-1300 ohms at room temp. the other possible cause is the heat relay on the control board is bad .this does not display a fault code.
Jan 17, 2008 | KitchenAid Architect Series KEBC107KSS...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
553 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
