Question about Polycom Viewstation FX H.323
Bad Video Quality in Sorenson VP-200 to PolyCom ViewStationEx Calls and vice-versa
         I work at National Technical Institute of Deaf, RIT, NY. In our campus there are many Sorenson VP-200  and
PolyCom ViewStationEx installed. I face issues in making calls from Polycom to Sorenson or vice-versa. I am able to make a call using the IP, however the call quality is really bad. There are lots of video jitters and the video hangs very frequently.
     I have tested it on both, local LAN (both Polycom and Sorenson within same subnet) and remote calls. The call qualities are really bad in both cases.
Re: Bad Video Quality in Sorenson VP-200 to PolyCom...
If connected to a Cisco Switch, make sure the EX is not set to Auto for Speed or Duplex.
Posted on Dec 14, 2007
0 characters
3 Points
Hi, I have Ploycom QDX6000 and facing two problems. Please let me know if you can help me to fix the same 1- I can not pick the call is someon calls but i can dial out successfuly 2- Fan-end camera...
1) try setting unit to auto answer and it will automatically pick up incoming call
2) far end will only control a Polycom camera and it will not work through a bridged call - it must be point to point
hope this helps you
good luck!!
Mar 31, 2011 | Polycom QDX 6000 (720030831001) Video...
We have an old model of the Polycom Soundstation. It doesn't have a screen. It has a hangup function, volume control, mute button, numbers 0-9 (of course) and a button called 'R' - do you know what this...
you cant answer numerous calls on this system - you will need to set up a dial in number on a phone bridge provider and have all participants call into that number and then all of you will be in same conference call. this is best quality and the most managable way to do this. i am sure your phone provider can help you set this up. R if i remember correctly is for redial
Mar 29, 2011 | Polycom SoundStation
I have a polycom viewstation FX and appear to have problems regarding the ISDN. We seem to be able to connect outgoing calls ok (however it does take a long time). But incoming calls do not connect, just...
How many lines (circuits) do you have going to your system? Is it possible they are out of order? Give me your ISDN numbers and I'll try to connect to you. Where are you located? My e-mail address is
Dec 08, 2010 | Polycom ViewStation ISDN (pcy220011323001)...
I have polycom 7000 with release version of 9.0.1 and second party having Polycom unit of 700 with release version now i am facing the poor video quality while connecting. Bandwidth at another end where...
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
Oct 14, 2010 | Polycom VSX 7000 Video Conference
Why the phone is hook off? how to fix it?
My grandaghter has D-Link Videophone DVC-1000. She got it set up and tried to call me. l have VP ( Sorenson - l am deaf ) . l can see her but she can't see me
Jan 24, 2010 | D-Link DVC-1000 Video Conference
Problem Obtain IP SCREEN BLOCKED, must restart unabled
My grandaughter has D-Link VP . She got it set up and tried to call me. L have VP ( Sorenson - l am deaf ). l can see her but she can't see me
Apr 21, 2009 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Connecting a polycom
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of:
- Cost
- Reliability
- Security.
ADSL would be better.
Jun 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out and
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Connecting VP calls to other devices
Evidently you are using the D-link service to receive calls. You will need to use the IP address of the VP100. D-link service is only compatible with D-link
Jan 12, 2007 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Conference Phones Logo
338 people viewed this question
Top Polycom Conference Phones Experts
Danny Nagdev
David Burbee
David Burbee
Are you a Polycom Conference Phone Expert? Answer questions, earn points and help others
