Question about Norelco 8894 XL Electric Shaver
What is the little water faucet symbol mean - Norelco 8894 XL Electric Shaver
  • 91 Answers
That is needs to be cleaned with the lid open under a flow of water. It does that after each use.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Posted on Aug 27, 2009
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
Water pressure in kitchen and front shower is weak,and it takes a little bit before the water starts getting warm.I put a new faucet in a couple of weeks ago the type where it has all the pluming in t
When water pressure in more than one place is weak, it means that there is some problems in the water pipe/supply. The chance of having problem in faucet/tap is low. I think you need to get a plumber to check the problem. It may be due to water heater problem or cold water supply problem.
Feb 06, 2014 | Plumbing
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
Hi, I have a faucet similar to this one and it is leaking from the top. I do not know how to remove the lever to replace whatever it is that may be needed. pls advise
I believe there is a set screw behind the hot and cold symbol on handle. remove symbol to remove set screw for handle. shut off water supply to faucet. after handle is off, then you can remove inside parts. use a pair of pliers to remove retaining ring under handle. then remove faucet spout by pulling it up. replace all bad O rings then put back together. have a good day !!
Jan 24, 2011 | Moen F7425 Chateau Single-Handle Kitchen...
How do I disassemble the shower faucet to replace seal
Take out the little plastic hot and cold water symbol from the handle and you should find a set screw in which you can remove to get the handle of for access to the main insert and seal...Hope this helps.
Sep 03, 2010 | Delta & Single Handle Shower Faucet
Umm..mine is called.."FOSSIL 10 ATM" there's also something written at the back saying, "stainless steel caseback, next a water symbol, then 10ATM..I'm just wondering what this means?? can I wear this...
10 ATM means that the watch is water resistant to 10 atmosphere's of pressure.
Long story short, yes you can swim with it. Yes, you can shower with it too.
Aug 02, 2010 | Watches
No water pressure at kitchet faucet
alot of times when you shut off valve under sink or in basement when you turn it back on you can get a little debri in faucet i would try cleaning the aireator the little thing on end of spout where the water comes out
Apr 14, 2009 | Moen Plumbing
Bosch dishwasher
The faucet symbol means there is a water restriction.
The filters or screen may be blocked
Jan 29, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Fridgidare Front Load Washing Machine
It means one of two things. You either did not use an HE detergent or you used too much, so that there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not getting in. The hoses need to be checked to make sure they are hooked up on the right faucets and the hot water faucet should be turned all the way on. You would also need to unscrew the water hose at the washer end and make sure the little filter is clean, so tha the hot water can get through.
Good Luck!
Jul 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Norelco 8894 XL Electric Shaver Logo
493 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
