Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Will not **** the water out of the carpet
I took the front bottom off to clean under it. Now it will not **** the water up.
  • 174 Answers
Is it on correctly, did you miss a gasket?
Posted on Jun 16, 2009
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
I am at my daughters trying to clean her carpets and i want to know if i set it up right to shampoo her carpets . i only put water and solution in the small container in the back,but i didn't add it...
The smaller container in the back under the release handle it the cleaning solution resevoir. The larger one in the front is for the hot water. It has an internal bladder that holds clean water in this larger container, while returning the dirty to the outer bladder chamber. Both need to be filled with water at the very least in order for the machine to work. If either goes empty, the machine will stop working.
Sep 01, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood...
do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ProHeat 7901 will not **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
adfa
Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Have Hoover SteamVac Model F5835-900. Has gunk under the front clear hood where water/debris is lifted from carpet to the tank. Wife wants me to remove clear hood to clean; however the hood cannot come...
There 2 screws on the bottom edge, one on each side, then there is a ***** on top at just beyond the lip of the window. Then it will come off of the machine.
Mar 11, 2008 | Vacuums
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
119 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
