Question about Kenmore 24 in. 17372 / 17374 / 17379 Built-in Dishwasher
Kenmore model 66516352301 diswasher flashes Wash but won't start
The "Normal Wash" button flashes. Start did nothing. When I pressed the "Cancel / Drain" button then it also flashed. I have tried to cut power to it overnight and a day to see if maybe something might "reset". This had no effect.
  • leftoverkarm Sep 23, 2009
    Is there anything I can coat the circuit board with after I again clean it to protect it from the elements? Cleaning the circuit board did indeed fix it. It worked for a couple of months but now the problem has returned. I?m assuming the circuit board needs to be cleaned again. This seems to me a design flaw. David
    Problem Solver:
  • 15 Answers
I had a simular problem with my Kenmore. I unplugged it for an hour or so and it worked for a while. (Disconnect dishwasher from power befer attempting this procedure!) I ended up removing the inner door panel and removing the circuit board. I used a clean damp (distilled water preferred) paper towel and wiped down the entire circuit board surface. I paid special attention to the areas between the closely spaced component leads. I dried the board with a dry paper towel and re-installed the board. The dishwasher has preformed flawlessly for the past 4 months.
I believe that the mist and steam deposites a thin film of very conductive detergent and minerals on the board surfaces over time. The resulting electrical leakage paths "scrambles" the control's "brains".
I also noted that prior to my repair, most of the led cycle indicating lights were very dimly glowing with the room lights out. Also, the wash cycle ran for a much longer time.
Posted on Jun 18, 2009
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 20, 2014 | Kenmore Dishwasher With Ultra Wash And...
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Diswasher not working
If you have a Kitchenaid. You need to press in this order.... high temp, energy saver dry, high temp, energy saver dry, the lights will all start blinking, after they are done the cycle will start. Press cancel twice. ;)
Dec 07, 2007 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kenmore 24 in. 17372 / 17374 / 17379 Built-in Dishwasher Logo
488 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
