Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
New washing machine, freshly installed, never operated...went to turn it on and it doesn't do anything when knob pulled out, but does make a humm sound like it's getting power...but nothing further? Is there something simple I can check first?
  • 82 Answers
I would make sure the water valves are turned on, the first thing the washer wants to do is fill. the humming noise is probably the inlet valves opening.
Posted on Jun 16, 2009
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
My kenmore washer series70 motor humms
yes there is a capacitor on most washing machine motors on a kenmore series 70 it should be on the right front panel upright leg
Dec 06, 2012 | Washing Machines
I have a Maytag dependable care quiet pack 2 speed super capacity 9 cycle Model No. LAT9416AAE
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
Nov 16, 2012 | Maytag Dependable Care LAT9706
I just moved into a new apartment and used a moving company to help me with my move. that included my washing machine. i just went to turn it on to do a load and it won't start. i hear a humm noise but...
Hi
Make sure the water taps are turned on. The humming sound is most likely from your inlet solenoids.
Check both the hot and cold water inlet hoses going to the back of your machine. Make sure they are connected properly and that the water is turned on.
If still no joy let me know and I will guide you through more trouble shooting items.
Ash
Sep 02, 2011 | Whirlpool LSR5132PQ Top Load Washer
The wash dial on my hotpoint wmf760 is not selecting
The knob needs to be removed and the knob and the mating part will need to be replaced. The teeth on these parts wear off with time. There is a clip on the back of the knob that pulls off this holds the knob on. Then the mating piece will pull out. Eneter your model # at www.appliancehelponline.com for diagrams and illustrations. All parts come with installation instructions.
May 03, 2010 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
