Question about Brother MFC 240C All-In-One InkJet Printer
Problem in color printing
Not able to print in colors from my mfc 240c after refilling inks
  • 10 Answers
I suggest making sure you installed them correctly, you can take them out and put them back in, it will ask you if you just replaced the cartridges one by one "select yes" if they are new, then try to print out a test sheet (which you do this through one of the options in your "menu" on the machine itself, it should be in your manual or you can look online in the Brother 240-MFC troubleshooting tips for printing, this just happened to me a few days ago and I got the answer there. So, when you print out the test sheet it will probably have colors missing and you say "NO' that it is NOT GOOD, and then it will do another cleaning and then print out another test sheet and hopefully it will work then, otherwise tell it NO again and have it do another cleaning, sometimes it does take a few times. This happened to me the other day when I replaced a black ink cartridge and I could not get ANYTHING TO PRINT, it kept coming out BLANK PAGES, so I went to the troubleshooting tips on the website and this was the advice I was given, it took THREE CLEANINGS and three test sheets before the black boxes printed out fully on the test sheet with none missing and ONLY THEN was I able to print successfully, GOOD LUCK TO YOU.
Posted on Jun 26, 2009
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I cant print in color
For reasons known only to Brother you are unable to print ANYTHING if you are out of any color of ink. If you are out of black and need to only print in color it WILL NOT work
Feb 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink does not print on brother 240c
If you haven't changed it recently, it may be out of black ink. The product code for Black is LC51BK.
Brother's supply site
Dec 10, 2009 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC-885CW printer. A friend
I have a Brother MFC-885CW also and I have changed the colour inks no problem but now I have just changed the black it will not print black.
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Won't print in color
Make sure you run the cleaning mode under the INK button. Run it 2-3 times to get the ink through the tubes. If you are using generic ink, it may have clogged the tubes in side the unit.
Jul 14, 2008 | Brother Multi-Function Center MFC-240C...
Magenta Color Doesn't Print
refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Feb 02, 2008 | Brother Multi-Function Center MFC-240C...
Problem with Ink Cartridge
If you only want to print in b/w and do not use the color ones there is a workaround.
Please notice that you will destroy the C/Y/M part of the print head because the ph needs the ink to prevent a dryout!!!
Simply stick some adhesive tape around the window in the middle between the ink-outlet and the valve. The flag inside signals the printer the inklevel (and also the cartridge being installed).
Nov 24, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
202 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
