Question about Dryers
Gibson modelGSE746RFS1 does not get hot. The tub turns and all the control seem to work correctly, but it does not get warm or hot. I am not sure how to get to the heating element.
    Sergeant:
  • 249 Answers
Could be the heating element, mine was a 20$ sensor screwed to the side of the heating element,dont remember the name of the part but it burns out when got too hot ,under the bottom of unit
Posted on Jun 16, 2009
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
How long does it take to heat the tub
Make sure that the inline heater has power. It should not take very long to heat since your putting hot water into it anyway. The heater is to keep water warm.
Jul 02, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
Hot tub not heating any hotter
It sounds as though the temp. sensor isn't operating correctly. The tstat may have the ability to turn the unit on and off but it may not be sensing the correct temp. I would have a service perfessional come out and check for a short and also that the tstat is operating correctly not just turning on and off. I wouldn't try and bypass due to safety concerns on a hot tub.
Mar 29, 2009 | Home
Series 2 esc 325p won't get above 85 degrees on full throttle
if using a aqualink and hooked into pins 1 and 2 on long plug turn heater all the way up and let the aqua link control heat
Feb 17, 2009 | Teledyne Laars Pool & Spa
Washing machine
a gibson has a bar with 2 bolts that holds it on the trans shaft .... remove it and keep trying to turn tub till it breaks loose
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely. Set the controls to the first wash cycle, and then try each water temperature setting. If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have. If hot works but cold doesn't, or vice versa: 1) Be sure both the hot and cold water faucets are turned on. 2) Be sure the supply hoses are not kinked. 3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets. 4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves. 5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
Top Dryers Experts
Marvin
Marvin
