Question about Samsung PCH521R 52" Rear Projection Television
Samsung SPT-521J Losing Color
Just found this site and thought it looked promising.
I have just purchased an older Model Samsung SPT-521J Rear Projection TV.  The Unit works well but the color does not.  LOL!
The unit starts up in Black and White and after about an hour or so the color comes on all at once.
My thoughts are that it's just a cold solder joint and that when the unit heats up, things expand... etc.  This is further backed up by the fact that the previous owner has indicated that a well placed "Tap" will sometimes start the color as well.
While I was an Electronic Engineering Technologist in a previous life, I have never worked on TV's and have no idea what board to start with.  While I'm waiting for an answer, I'm going to go at the unit with heat and cold and see if I can find the problem.
Any help would be appreciated.
    Problem Solver:
  • 16 Answers
Re: Samsung SPT-521J Losing Color
There is a large shielded module mounted vertically on the signal board (leftside when looking from rear) You need to resolder all the connections. This is a very common issue............Good Luck
Posted on Oct 31, 2007
0 characters
3 Points
I have a samsung Spt-521J 52 inch rear projection tv, and the image on it is curved at the top like the colours are out of whack i also see red a green thin lines at the top of the screen. Any suggestions...
it sounds like a convergence circuit failure most likley a couple of ics and always the possability of a couple resistors being out of tolerance and there are also pico fuses on source voltages to the ics
if you have the tool and and can solder its a doable task if not you may want to call a local and get a est for convergence circuit repair
to repair it will require the components to be replaced to correct the problem
Jun 05, 2011 | Samsung Projection Televisions
We have a HCM4215W 42' projection TV that we purchased in 2003. Our picture has color shadows. Perfect focus doesn't work and neither does manual convergence. This happened in 2006 when it was under...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as
Feb 24, 2011 | Samsung HCM4215W 42" Rear Projection...
We have a 50inch ultra-vision, the picture seems to be dim and losing its color
If the set has not been serviced in several years and the picture slowly got darker and or duller looking you may just need to try something simple.
With the set unplugged and the back cover removed look for the three lens----I presume it is a older set called rear projection and not a DLP, the model number would tell me which it is.
If older you will find three large black lens near the middle, clean them free of dust etc with a lens cloth and check the picture again.
Let me know model number if you need further help
Jan 10, 2011 | Hitachi Projection Televisions
It sounds like a fan blade is hitting or rubbing on something @ the picture is a little off color wise
If you hear like whirling sound and vibration on the TV,it looks like the color wheel bearing is loosing balance and is hitting the housing unit,the color wheel spins @ 5000 rpm you will definitely notice when is going off i have this link that i found i hope it helps it's not your TV model but at least you will have and idea of what you need to look for.
good luck
Nov 10, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
The color on the screen comes and goes. sometimes it will work fine for a long time then it may come on and off. Samsung SPT-521J
Re soldering all the Circuit board that already cracked by the heat should fix the problem.
To make sure of it, only re soldering on the RGB Board.
Oct 18, 2009 | Projection Televisions
How do I access the color wheel on my Samsung HLP4663W?
Looking from the rear of the set, the color wheel is just to the left of the lamp, underneat an aluminum heat sink. You have to remove 7 screws to get to it.
May 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
Dec 13, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung PCH521R 52" Rear Projection Television Logo
365 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
