Question about Motorola Mobility Motopure H12 Bluetooth Headset
My headset is paired with my phone but i can not hear anything. people can hear me but i can not hear them or the phone whenit rings. i have turned up the volume but still nothing.
    Problem Solver:
  • 13 Answers
Its broken for good return it asap
Posted on Jun 16, 2009
Bluetube is connected to my cell phone but I can't hear anything
There may be linking issues between the headset and the phone. Page 11 of the user guide offers these suggestions. Also, here is a link for re-pairing your headset to the phone:
Plantronics Explorer 230 Pairing Instructions
Remember that you want to purge any possible bluetooth interference from your phone.
"Callers cannot hear me or I cannot hear caller/dialing tone:
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset."
Good luck from Headsets Direct!
Jan 10, 2012 | Plantronics Explorer 232 Bluetooth Headset
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
I cannot hear anything. Headset is paired and connected, but I cannot hear anything at all.
You want to remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone pairing information for your Voyager Pro headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics Voyager Pro. That should get some sound back in your headset.
Plantronics Voyager Pro User's Guide
Apr 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
Can't talk or listen with Paired headset
mine was doing that because the accepting device somehow changed settings...might check that
Mar 12, 2008 | Plantronics L510 Consumer Headset
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H500 Wireless Headset Pairing Problem
If you turned it on and it was steady blue most likely you held the call button too long. The steady blue means it's ready to pair with a phone. Try repairing again and if you still don't hear anything, play with the volume buttons to the top and buttom of the headset the volume may be down. If that doesn't help I don't know what will.
Aug 20, 2007 | Motorola Mobility H500 Wireless Headset
Can not hear on bluetooth
my headset works fine if I get a incoming call.When I dial out no one can hear me.
May 09, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility Motopure H12 Bluetooth Headset Logo
411 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
