Question about GE GSL25JFPBS Side by Side Refrigerator
Freezer Help we have a whirring noise in our freezer that wont quit goes from low to very high pitch. Do we need to adjust something ourselves or do we need to call in a repairman. What is wrong with our freezer patti
  • 10 more comments
  • jec2you Dec 21, 2007
    Noise is not a fan touching anything. It is a whistling sound like wind whistling outside on a windy day.
  • Anonymous Dec 30, 2007
    I have the same problem and was wondering if it could be a controller rather than the motor. The fan seem to go fast-slow-fast-slow-fast-slow varing in about 1 second intervals making a strangle whirring sound as it changes speeds.
  • Anonymous Jan 27, 2008
    I have a GE Side By Side Refrigerator that has a whirring noise that goes for 45 minutes to and hour and then turns off for 45 minutes to an hour. To stop the noise for 45 minutes I turn the freeser and refrigerator off for a couple of seconds then it starts up again in 45 minutes. (smile)
    Any solutions? My repair guy came and the noise was off!!! Of course
  • Wxwvlg Mar 19, 2008
    Fan in freezer goes from high to almost a stop and then up to high
    again. Removed ice bin and shelf and found several ice cubes jammed
    back near the fan outlet. Seems to be OK now, but ice maker continually
    makes too much ice, making it hard to remove the ice storage bin. Can't
    seem to adjust the paddle that stops the ice making process.
  • weboss Apr 16, 2008
    Exact same problem here. Ours is the GSL25JFPH BS side by side. The whirring noise is coming from the freezer section and will cycle about every 30 to 45 minutes. When it is making the noise it ramps volume up, stops and starts over. I have another fridge and thought it needed defrosting so I emptied it completely and unplugged it for several days. Plugged it back in and the sound is back. Fridge is 3 years old and worked good till a few months back. HELP :(
  • naatch_1 Apr 17, 2008
    I have a 3 1/2 year old Model GSL25JFPE BS that is also making the same wind noise at a certain speed (which it runs at most of the time). I've taken it apart several times without fixing the problem. There is not frost/condensation buildup anywhere. Its rather embarressing as friends and family have asked the following; "Is that noise an airplane outside", "do you live near a train track", or "are you brewing hot water in a tea kettle".
    All these other complaints don't make me feel any better but at least I know its not just in my head.
  • aprie Sep 17, 2008
    This thing is howling like I'm at the north pole.
  • Anonymous Nov 21, 2008
    Same exact problem with GSL25 JFPE. It sounds like wind continuously blowing through my freezer. The refrig is approximately 5 years old and just started making this noise.
  • Skyman65 Jan 10, 2009
    Exact same problem as described by others. Whirring sound coming from freezer. Fan cycles from fast to slow. Sounds like I'm at the North Pole. I took the panels off from the back of the freezer interior and found the fan motor. Tried spraying WD40 on the fan shaft. Didn't help. It seems like is it the controller, not the fan motor itself. From all the other posters here, it seems like a common problem. Surely someone knows what causes this?!?!
  • robertlewis2 Feb 14, 2009
    same problem. Sears repairman came and said I need a new fan motor for $75, but wanted another $200 to put it in. I asked him long it would take to fix....15 minutes.
    I guess I'll try it myself.
  • chra Feb 17, 2009
    I don't have this exact model, but one similar and have the exact same problem described by everyone.  I have asked several repairmen and they always are trying to "fix" the machine.  The problem is simple: GE designed a very noisy and loud freezer.  The only solution is to sell the refrigerator and buy a new one.  You'll only throw money at it trying to fix it because it is freezing perfectly and is just one repairman's "I think this will solve it" after another.  No definite solutions.  If you still can, return it or complain about not being "fully satisfied" if you purchased a protection plan from the store you go *** at.
  • Anonymous Feb 24, 2009
    RE: Solution #2
    It looks like that motherboard is for the single speed fridges. Basically meaning that you are swapping out your "energy efficient" multi-speed motherboard (that you paid extra for in the first place) and reducing it back to a normal single speed fridge.
    Awesome for solving the problem. Too bad it means we should have just bought the lower model to begin with! I just went and got a new fridge... Going to sell the old one on Craiglslist as a garage fridge.
I have a GSL25JFPH BS refrigerator by GE. It made the whirring sound, a repairman came out and told me that the fan motor needed replacing, price of $277. I sent him away, and after a few minutes on the internet, saw on this site that a new circuitboard (part# WR55X10656) should fix it. I found it on ebay for $83, and it took about fifteen minutes to install. No more whirring!!
Posted on Feb 22, 2009
  • robertlewis2 Feb 22, 2009
    ok, after I sent the Sears man away, I did looked on the internet (maybe this site) and saw a recommendation to replace the circuit board (part# WR55X10656) to correct the problem. I found one at the best price on eBay, it took about fifteen minutes to install, and the problem was solved. no more whirring!
OK.... THis may sound strange, but the problem is the fan location on the shaft of the fan motor. I replaced my motor assembly.. and when it came time to put the fan on the shaft it slides on to no particular position. The old fan motor still works good... All you need to do is pull the fan forward a little on the shaft and it will change the air flow pattern through the cavity. THey should have put a clip in place to hold the fan blades.
Posted on Feb 26, 2009
  • 291 Answers
Sounds like a evapurator fan motor in freezer..  take back panel of freezer and look for frost build up or anything that may be touching the fan to make noise.. IF noise comeing from fan replace it
Posted on Oct 31, 2007
Low pitch whirring sound coming from front end when above 30 mph
It could be that you have a front wheel bearing that is getting noisy. Have someone ride in the RF seat and listen to the noise to try to figure out which front wheel the noise is coming from.
Also , check the tread pattern of the front tires to see if it has some unusual choppy pattern forming.
Jan 09, 2015 | 2001 Buick Regal
My computer makes a highish pitched whirring noise every time it has to do something slightly difficult, typically a video or interactive things. What is it and can I fix it?
Yes, open the side cover and determine where the noise is coming from - Harddrive, fans, DVD/CD player, etc.. If it's the harddrive, start backing up your important data asap before it goes out completely. If it's a fan, power down the computer and clean the fan. If it's t DVD/CD drive, replace the drive.
Nov 08, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
When we first start the unit, it has gotten quite a loud whirring sound. We turn it off, then turn it back on and the noise virtually disappears - it's still there, but greatly diminished. I suspect...
that is the fan on start-up and the high pitch is the power supply components heating up make shure that the main fan is working always it will be slow at low volume if it quits you run the risk of the power supply failing
Jul 13, 2010 | Koss KS4192 System
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
2000 Beetle Loud Whirring at start up
its your secondary air pump. it turns on in the cold morning to inject more air into your exhaust, something about emission. its normal to be high pitched. once on my car it was way loud, i looked and the hose had disconnected. either way its normal if its not super loud. but if its everyone is looking at me loud then check for loose hoses!
Apr 03, 2009 | 2000 Volkswagen Beetle
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
97 4runner making a low whirring noise/whine from engine.
Could be a possible break down of the plug wires. Seems that I remember hearing if your plug wires are breaking down inside and if its up against the motor you can hear something that sounds like interference in your radio. Just a thought, might want to check it out.
Feb 14, 2009 | 1997 Toyota 4Runner
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Compressor problem
The click your hearing is a thermal cutout that is kinda like a little breaker, it gets to the temp that it is designed for and trips. If its making a high pitch noise, more than likely the compressor itself has gone out and needs to be replaced, its getting a high load and triping the thermal cutout.
Sep 21, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
GE GSL25JFPBS Side by Side Refrigerator Logo
686 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
