Question about GE Profile PSS26NGS Side by Side Refrigerator
I have a GE Profile Side by side that is working fine except the ice maker won't dump the frozen ice cubes in the tray. Another party in the house decided it would be a good idea to put water in the tray manually. Now it seems overly full and frozen to the point that the arms aren't turning out the ice. Any ideas? It started by not filling the hopper. I haven't checked to see if the model listed is the exact model or not, but its close.
  • 10,865 Answers
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Posted on Jun 16, 2009
  • Liza J Aug 27, 2010
    1) How long does it take to defrost the ice maker with the blow dryer and 2) do I focus the warm air to a particular area of the ice maker or all over?
    Thanks
  • notjoe Aug 12, 2011
    Why not just remove the ice maker from the freezer? Much easier and less mess.
Ice maker not working has frozen ice inside tray and had cubes on top it's just no longer moving
remove tray, ice may be frozen around auger or gear that spins auger, dump all ice and start over making ice. also, wile tray is out hi dispense switch and see if grer spiindle rotates, if not ur motor has gone bad
May 22, 2010 | Kenmore 53603 / 53606 Stainless Steel Side...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
I am unable to get ice. Cleared the tube.....arm on ice maker is down. I have a ge performance profile TFX22PP
Pour about 1/2 cup of water into the icemaker . If it dumps the cubes after freezing , replace the water inlet valve . If it holds the frozen cubes and does not dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc ...
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSS26NGS Side by Side Refrigerator Logo
572 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
