SOURCE: Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
SOURCE: red water light is flashing
Check your water flowmeter. Check the turbine is not scaled or clogged.
SOURCE: Coffee maker does not dispense product, instead,
It sounds like there is a restriction in the line between the pump and spray nozzle and it is being pushed back out the vent line. I would try running the cleaning cycle per the instructions in the manual. I would use a slightly higher concentration of vinegar to try and clear any hard water deposits causing a blockage. Also try soaking the spray head with vinegar using a small shot glass an see if that helps. If it is within the warranty period I would send the unit back to Keurig if the cleaning cycle does not fix it.
SOURCE: I have a Keurig Platinum B70. When it brews,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: Hallo, I have a Breville
Regards,
Tony
heatman101
