Question about Garmin StreetPilot 2610 GPS Receiver
Trouble finding satellite-Garmin Nuivi 260w
My garmin 260w sometimes has problems finding satellites. It is not as consistent as it was 2 months ago when it was new. The other day it gave the trouble finding satellite error message. There wasn't a cloud in the sky. Any suggestions?
  • 3,866 Answers
Suggestion that the battery in this thing is getting old or is not fuctioning as it is supposed to it would not matter if it was connected via cigarette lighter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 16, 2009
Problem with Garmin Nuvi 260w
No because the date recorded in the unit would have been set via satellite and cannot be changed.
Jan 08, 2010 | Garmin nuvi 260W GPS Receiver
Hi, I have a garmin 260W that I use at home ( washington state). I purchased a download for France and downloaded it successfully. I have the map of france, but it is not locating the satellites - (...
When you change the location of your GPS drastically (taking it to another country), it sometimes takes 20-30 minutes for the unit to acquire the satellites and re-set itself for that country. Leave it in an area with open sky, and wait for it to find the satellites, then you should be able to navigate.
I know this solution might be too late for you, but I'm posting the solution in the hope that it can help others with the same problem.
Nov 12, 2009 | Garmin n?vi 260W GPS
My Garminis taking a really long time to acquire satellites( sometimes 5-10 min),especially when I flip the top up to turn it on and whenI flip the top down to turn it off ,it acquires the satellites...
are you inside when trying this ? Garmin has a very bad reputation in acquiring satelites when in coverered position.
Go outside and you will notice it goes much faster.
Aug 11, 2009 | Garmin nuvi 260W GPS Receiver
My screen will always states "acquiring satellites"
Have you updated your Garmin in a while? To update it you need to download their Webupdater program from their website.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
From here follow the instructions. A simple update of your GPS may fix this problem.
May 20, 2009 | Garmin nuvi 260W GPS Receiver
Trouble locating satellites
Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
Apr 24, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Since my last time i used garmin nuvi 260 it cant find a signal
Try going outside with a clear veiw of the sky, since it cant aquire a satellite its simulating the last place where you were. Try canceling the route and see if it connects with the satellite.
Jan 08, 2009 | Garmin nuvi 260W GPS Receiver
Cannot locate satellites
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor or inaccurate GPS tracking, and taking a long time to acquire satellites, are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Nov 23, 2008 | Garmin nuvi 260W GPS Receiver
Takes forever for garmin 260w to locate satellite signal
it takes forever to get a gps signal on my garmin 260w , can you help please . thank you .
May 25, 2008 | GPS
Garmin StreetPilot 2610 GPS Receiver Logo
227 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
