Question about Konica Minolta Office Equipment & Supplies
Report code 35-02 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
GO to 25 mode Holding down the 2 and 5 keys while turning on the machine, Select Soft switches (SW) then select 03-1 will be 1 in the third position change to a 0 then exit out and power off, then power on again
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 29, 2009
How do I do a Z report
There are special codes on most machines depending upon the type of report you need. Use the codes in the manual to create a report. If you don't have a manual, one of the users has most here:
https://the-checkout-tech.com/
Oct 08, 2015 | Retail Supplies
Hp cm4540 configration device code
Not sure if you just want to print a configuration or if you have an error code. To print a configuration page
  1. Scroll to and touch the Administration button.
    1. Open the following menus:
    1. Reports
    • Configuration/Status Pages
    • Configuration Page
  • Touch the Print button to print the report, or touch the View button to view the report on the screen. The report consists of several pages.
    I
    Aug 24, 2014 | HP LaserJet Office Equipment & Supplies
    1995 VW Jetta fault codes will not read
    Hi Gregory, take the vehicle for a diagnostic scan. I am not very sure what question you're asking. I believe that you may be reporting that code 4 and 15 are reporting faults. If there are no fault codes the scanner will report 'No fault code" If it shows the two you report, a fault has occurred in those two areas. Regards John
    Jul 01, 2012 | 1995 Volkswagen Jetta
    Device not detected
    Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
    Feb 17, 2012 | Gigabyte GE-S800A-D1 ODIN GT 800W POWER...
    How do you Z out a 435dx
    "Z" (Prints End-of-Day Management Reports and Resets Totals) - Prints the "Z" management report at the end-of-the-day and resets totals to zero (except "locked-in" grand total).
    To print Management Reports, slide the control switch to the "X" or "Z" position as needed, then press the [amt tend/TOTAL] key. Refer to explanation starting on page 37.
    "X" AND "Z" SALES MANAGEMENT REPORTS
    __________________________________________________________________
    Transaction data is maintained in the memory of the cash register as long as the battery back-up system is in effect. This data can be printed as a report for management review.
    The Management Report can be printed from either the "X" or the "Z" position on the Control Switch.
    "X" POSITION REPORT (Refers to a mid-day reading)
    The "X" position report prints the accumulated information and RETAINS ALL TOTALS IN MEMORY. Use this position to print periodic readings of transaction information at any time through-out the day. (Some users call the X-report a mid-day report).
    "Z" POSITION REPORT (Refers to an end-of-day or close-out reading)
    The "Z" position report prints the same information as the "X" report. However, once this report is printed, ALL TRANSACTION TOTALS ARE RESET TO ZERO except the Grand Total. (Some users call the Z-report an end-of-day report).
    NOTE: To prevent accidental printing of the "Z" report, set the security code as explained in the SECURITY CODE section.
    Once this code is set, a "Z" report will not print until the security code is entered. If a "Z" report is attempted without entering the security code, the prompt "SEC Code" will appear in the display.
    PRINTING THE SALES REPORT
    IMPORTANT: Once a "Z" reading is taken, it cannot be duplicated, so be sure to have plenty of paper in the register.
    1. Set the Control Switch to either the "X" or "Z" position.
    2. Press the [amt tend/TOTAL] key.
    NOTE: If a security code has been assigned, be sure to enter the security code before pressing the [amt tend/TOTAL]
    key.
    TO CLEAR THE GRAND TOTAL:
    1. Set the Control Switch to the "prg" (Program Mode) position.
    2. Type [2], type [0], then press [RA].
    After this operation, the grand total resets to zero.
    Oct 21, 2011 | Royal 435dx Electronic Cash Register
    Yellow light on and the driver report an error code: E198 0000 What does this code mean please.
    Jun 26, 2009 | Canon LASER SHOT LBP-5000 Printer
    How to create crystal report in asp.net with vb script code
    You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
    Apr 15, 2009 | Computers & Internet
    How can i get a fax from memory.
    Solution: Printing reports and lists MX310
    Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
    Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
    LIST
    Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
    REPORT
    Prints after transmission of a document.
    You can enable or disable this feature, or set the machine to print a report only when an error occurs.
    You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
    RX (Reception)
    REPORT
    Prints after reception of a document.
    To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
    2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
    3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
    Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
    Eurovox codes
    codes From 4th of December
    Enjoy
    LATEST KEYS ALL AREAS
    EX C&W KEYS -- KEYROLL 04/12/2008
    PROVIDER CODE: 5C 01
    KEY 00 = D4 A3 5D EB 7B F3 69 59
    KEY 01 = 27 77 A1 FC 8F 9D 34 76
    TELEWEST KEYS -- KEYROLL 04/12/2008
    PROVIDER CODE: 5A 01
    KEY 00 = C0 F6 61 87 91 F9 67 57
    KEY 01 = F0 83 35 E5 28 40 49 B2
    PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
    PROVIDER CODE: 54 01
    KEY 00 = 3F B8 36 62 72 E5 E2 76
    KEY 01 = 35 5E D6 40 6E AA 99 41
    IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
    PROVIDER CODE: 5E 01
    KEY 00 = 51 0F 32 A7 D9 34 BE 3E
    KEY 01 = 8D A3 88 1B 4E 32 C5 8F
    IRELAND NTL KEYS -- KEYROLL 18/06/2008
    KEY 00 = 75 92 B1 CC 6F 23 20 F1
    KEY 01 = F2 46 B1 59 04 61 77 71
    Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
    View Reports
    Hi, There a couple of different way you could do this and I have put two lots of VB code below that you can modify and use. Firstly you create the Combobox list by choosing the option that you will type the values yourself, you then type in all your report names on each line. After that you can then go to the VB code editor and paste my code in and modify it by changing my report names, (Customers) etc to your report names. Make sure you choose the Combobox and the On_Click option in the VB editor to paste the code into.  I like the first method better which checks the value of the Combobox and then opens the corrosponding report in the maximised form. The second method does the value check before running an assigned macro to open each report. With this you must first assign macros to each report in Access.  Remember each of these bits of code must be placed between the "Private Sub" heading and the "End Sub" ending, and change the "Combo23" name to reflect your combobox too. If you need a hand just email me.
    First Method
    If Combo23.Value = "Customers" Then
        DoCmd.OpenReport "Customers", acViewPreview, acWindowNormal
        DoCmd.Maximize
    ElseIf Combo23.Value = "Customers 1" Then
        DoCmd.OpenReport "Customers1", acViewPreview, acWindowNormal
        DoCmd.Maximize
    ElseIf Combo23.Value = "Customers 2" Then
        DoCmd.OpenReport "Customers2", acViewPreview, acWindowNormal
        DoCmd.Maximize
    End If
    Second Method
       DoCmd.RunMacro "Macro1"
       DoCmd.Maximize
        DoCmd.RunMacro "Macro2"
        DoCmd.Maximize
        DoCmd.RunMacro "Macro3"
        DoCmd.Maximize
    End If
    Oct 28, 2007 | Computers & Internet
    77 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    carpediemweb
    Level 1 Expert
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
