Question about Plumbing
Tran charge pump presure low. changed pump volvo loader L70C
Tran charge pump presure low. `changed pump volvo l70 wheel loader
    Problem Solver:
  • 16 Answers
Stopped up suction screen can cause this. Also pressure regulator.
Posted on Oct 12, 2009
I have a 2005 Volvo v50 no fuel presure replaced fuel pump still no fuel presure
Is the fuel pump relay working? jumper that relay to power the pump. If relay is ok then check the wiring to the pump.
Feb 17, 2018 | Volvo Cars & Trucks
No spark on xc 90 v0lvo changed motor all dash lights plenty fuel presure.
The best way here is to use the Volvo VIDA software and interface to get a readout on what the car is complaining about.
Look for an aftermarket Volvo shop. They will have the computer interface and charge you less than the dealer to read the codes.
Dec 20, 2017 | Volvo XC90 Cars & Trucks
My 1999 Volvo s80 2.9 would not shift out of 3rd gear for about 500 miles. After a 3 1/2 highway trip upon exiting the freeway the trans no longer worked. Engine runs fine but no power to wheels. Is this a...
Most likely an electrical issue. If driving so long in third didn't blow it. Most common issue I have came across are shift solenoids. Did any codes/ lights come on the dash? Shop time for replacement is around 7- 7.5 hours. Not easy to get to. And worth changing all at once, assuming that's the issue. Did the car shift into neutral after third and then drop back to third?
Jan 27, 2015 | 1999 Volvo S80
Why is my steering-wheel wobbly and seat at low speeds
Did you tried to check the hidraulic liquid level and check the presure pump for the stering wheel, also are there any liquid leaks
Jun 13, 2014 | 2000 Nissan Maxima
P0087 p0088
code p0087 is pressure too low--- causes include fuel supply pipe blockage and code p0088 refers to fuel return line blockage. While you have changed every thing covered in the causes I suggest you have a look for a common point that the pipes run together that could be kinked or squashed . The low fuel pressure could be from a vacuum in the tank from a faulty cap . If the lines are rubber and run in the boot check that something like a spare tyre is not cutting off fuel supply and return
May 13, 2013 | 2005 Volvo XC90 D5
Automatic transmission takes to long to change gears, rev's going up to high before changing to the next gear. What could be the problem?
trans oil low level,oil presure to low or oil presure to high1st ajust the cable for trans or the bens front cluch.
Jun 04, 2012 | Isuzu Pickup Cars & Trucks
Volvo xc90 2004 buzzing in steering wheel, clunck noise under car
that sounds like you are low on power steering fluid ... when the level gets low then the pump starts to ingest air and that produces a buzzing sound when you turn the wheel .....i would add or change the fluid and check for leaks and mechanical loosness in the under car linkages ...you can have that checked at your next oil change .
Apr 10, 2010 | 2005 Volvo XC90
710 d has problem in hydrolics ax like main pump is destroking to soon no power in all hydrolics. did presure test found low presure in charge circuit on test port on main pump .have checked or replaced...
hydraulic pump may be going out, you have to have a good working pump for your hydraulics to work right, there are also some check valves that could be leaking, this will also give you a low pressure reading, low pressure will also effect pto engagement
Oct 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Accumulator charging valve
This sound weird but the small pump on the back of your steering pump is the brake and pilot system supply. It is the possible source of your problem. Check for flow from the pump. At low idle there may be low flow.
Jun 19, 2009 | Caterpillar American Construction...
Plumbing Logo
148 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
