Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Arches of words and top and bottom doubled with red words
My philips rear projection tv just started doing this.  Has an arch at bottom of words in red over the regular words and at top.
  • 1,694 Answers
Re: arches of words and top and bottom doubled with red...
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Posted on Nov 21, 2007
0 characters
3 Points
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence on Projection screen
More than likely the repair company used cheap chips when they did the repair. The cheap ones fail real quick. Goto the site They have built a kit that you can do yourself. It includes name brand chips and a photo instuction guide.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Arch on top and bottom of tv
You can try adjusting the convergence manually, but this is not a good symptom for your TV to have.
Look at this Quick Start Guide, p. 7:
Mar 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
RED arched lines
Nov 17, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
