Re: Toshiba Satellite L25-S119 Laptop will not power on
You more than likely have damage to the motherboard. If it's still under warranty they will probably clasifiy this as abuse, and charge you for the repair.
It seems like you intetnet explorer has crash down due to many reasons it cant be corrected eaisly so I suggeyt you to use another browser like chrome or mozilla
The Toshiba web site has all you need. Just enter your model number and follow the prompts. The web site can even get all the information from your Satellite for you if you are not sure. Click here.
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
If it is the drivers you require the Toshiba webite should have them. If you call them with make/model seriel # they may be able to provide you with a replacement recovery disk. Hope this helps.
