Question about Nintendo 64 Console
Will my Nintendo 1 work with cable tv - Nintendo 64 Console
  • 24 Answers
As long as it has a composite input (yellow plug) then it'll be fine.
Posted on Jun 16, 2009
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Jan 23, 2013 | Nintendo 64 Console
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
May 01, 2011 | Nintendo Wii Console
Does anyone know how to set up an old nintendo game
I am assuming you mean a nintendo entertainment system (NES)
You Need:
The gray master console
At least 1 controller
Power supply
RF Switchbox (Must be an auto switchbox) or an A/V Cable with RCA ends
The power supply & RF switch plug into the back of the grey master unit. Hook the RF switch up to the cable connection on your TV. (If using the A/V cable - it plugs into the side of the master unit & into a video in - yellow plug/audio in - white plug) Plug in the power supply. Make sure a controller is plugged into the 1 outlet on the front. Make sure a game cartridge is inserted & locked in (You push it down). The TV needs to be on whatever channel the switch is set on if using the RF switch (Channel 3 or 4). Turn on the power & it should work
Jan 03, 2010 | Nintendo DS Console
Can't not get our Nintendo 64 to work on our new Bravia TV
The Nintendo 64 sends out a signal that can only be properly decoded by old CRT TV's
Those Bravia TV's are the God's TV's even if they did work on it I wouldn't recommend it because it would most definitely eventually ruin the life span of your TV.
But to answer your Question the Cables should be plugged into AV1 which is the Red White and Yellow Connections
Nov 22, 2009 | Nintendo 64 Console
TV ONLY HAS SNOW AND LINES. wE CAN HEAR THAT THE Wii is on, but can't see the screen. I think it's the audio/video cable.
Try the wii on a different TV. You can try replacing the audio video cables.
If all else fails:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform.jsp
Setup a Repair Online:
http://www.nintendo.com/consumer/repair/repair_charts_wii.jsp
Nov 19, 2009 | Nintendo Wii Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
Nintendo 64 Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
