Question about RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
L shut the tv off when l went to bed .in the morning l tried to turn on tv there was nothing no picture and no sound and l check all the connections?
  • Richard Tirado May 11, 2010
    Do you have power going to the outlet it's plugged into?
I have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Posted on Aug 25, 2009
This worked for me also. I bent the prongs further apart to achieve a tight connection with the power supply cord (as you are looking at the TV the power cord is on the rear right side and disconnects at the TV; bend the prongs on the TV and simply place the power cord back on) Thanks, saved me about $330 on a new TV!
Posted on Jul 02, 2010
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
No picture, no sound, nothing but snowy screen. Have turned TV off and then back on, same problem.
well snowy screen is good. It usually means that your antenna is dosconnected check coax and alls connections
please rate my help++++Thanks for using FIXYA
May 19, 2010 | RCA L32WD22 32 in. LCD HDTV
Rca 32 inch hd tv wont turn on
Josh,
Take your unit to a service center where they repair tv in your city.
Ask them to repair it. Because there are no repair manuals they will not repair.
Make sure they use a work order. when you pickup your tv.. make sure you get the work order or a copy.
With that order... call 1-877-297-8391 and get a new tv
Apr 11, 2010 | RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
I have an rca tv and vertical lines show up when i power the tv on model # is L32WD22
Tumble9827
Pls take your Tv to a Service Centre nrear you. Ask them to repair, and if they say they can't... Get that in writting on a Work Order,
Then call 1-877-297-8391
Dec 24, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32 in. LCD HDTV Logo
1,836 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
