Question about Cycling
My father has a Huffy 3 speed Sportsman that he has had over 20 years. He is having a problem adjusting the gears on the handle bars. Could you please give me directions on how to adjust the gears or resources on where to find help on how to adjust the gears. Thank You V.
  • 3 Answers
Go to youtube, directions are there
Posted on Jun 16, 2009
How do I adjust 7 speed shimano on Huffy?
Cable adjustment is complex. Suggest taking your bike to local bike shop for assistance
Sep 08, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Huffy stalker 18 speed, I can't tighten the stem.
If you are talking about the handle-bar stem, the bolt you need to tighten is right in the middle of the post. It may have a snap-on plastic cover over it. This will be the head of a long bolt that reaches down inside of the stem where the nut is shaped as a wedge that serves to tighten inside the tube of the front fork. If you are talking about the the seat-post, then your seat-post might be of too small diameter.This page shows a good picture of the handle-bar stem bolt and wedge nut.
http://www.bikewebsite.com/bikeoh.htm
Mar 03, 2013 | Cycling
I have a late 70's huffy saratoga bike that came
All you have to do is put a distilled version of your request into a search engine "adjust shimano 3 speed internal hub" and voila - videos and other resources.
http://www.parktool.com/blog/repair-help/internal-gear-hubs
Jul 11, 2011 | Cycling
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Ball bearings fell out of handlebar connection on 3-speed bike.
Take it to a professional bike shop. They have the knowledge and tools to set it right.
Or take a look at this:
http://www.sheldonbrown.com/headsets.html
The headset nuts were not necessary to be moved for handlebar adjustment. Now the bearing load is too tight. Correct adjustment of the headset requires a delicate balance between tightness and freedom of movement. If your bike has/had the original bearings it's a safe bet they may be due for replacement anyway.
Apr 26, 2010 | Huffy Womens Mountain Bike - Passion...
Older bicyles
Hello. here is the link to a site about bike history that you may enjoy. http://threespeedgallery.blogspot.com/2009/04/1963-huffy-sportsman.html
Also, go to Raleigh.com and check them out as they are the manufacturer of the Huffy.
Mar 22, 2010 | Cycling
How do I fix the handle of my huffy blackwater women's bike so that it synchronizes with the wheel?
Try this website and look under repair help:http://www.parktool.com/index.asp I think you are try to adjust your derailleurs. Also check this website under gear shifting:http://sheldonbrown.com/gearing/index.html I hope this will help.
Aug 10, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
I have a Huffy Timber Creek 10 speed and I would like to move the handle bars up 3-4 inches. Can someone help me figure this out?
go to your local bike shop and ask for a stem extension piece, take your bike w/you to ensure you have enough cable slack to accomodate the modification...good luck to you friend...Tim
Jun 04, 2009 | Cycling
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
May 31, 2009 | Huffy So Sweet Girls 20-Inch Bike
Cycling Logo
224 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
