Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Must hold down wall switch for the door to close all the way or it reverses back up (and neither remote will close it at all). The overhead light blinks too.
  • 10,865 Answers
The problem is an easy fix. There are two screws on the side of the motor which adjust up and down pressure on the door. Generally, when the problem you are describing occurs the adjustment is to decrease the down pressure about 1/4 turn.
Posted on Jun 16, 2009
    President:
  • 3,197 Answers
You have a problem with the door sensors. Anytime the door reverses to the open position and the main light flashes 10 times it is a sensor problem. Check your sensors and make sure the small light on each one is lit and not flickering. They must be pointed at one another to work properly. Tweak them until the light on each one is on.
The door closes but then goes up without touching the remote. I tried it in the garage and outside but the same thing happened. Installed in 2007
check safety obstruction lights mounted close to bottom of door.
The most likely reason is that your lower travel limit needs adjusting. Your door may have settled or shifted due to age and weather changes and now contacts the floor before the lower limit switch is triggered. The opener sees that as the door not being able to close completely and, since that could be caused by something or someone trapped under the door, it reversed the door back to the open position as a safety precaution.
If the door only does this with the remote and you need to hold the wall switch button continuously to bring the door down then there could be a problem with the safety sensors near the bottom of the garage door itself. Again, the opener would see a problem there as a potential safety concern and re-open the door. Typically, however, a safety sensor issue will cause the remotes not to work at all and will reverse the door long before it reaches the floor. And any problem with the safety sensors should also trigger flashing of the overhead light.
Your owner's manual and the links below have more information that should help locate and resolve the issue.
Jun 24, 2018 | Building Materials
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
I have the same problem that is listed above with my 1/2 horse power belt drive garage door opener. The lights on the sensors are both green and the alignment works, the overhead light will turn on if the...
Sounds like you have a couple problems. The opener is in the lock mode which is the reason the remotes will not work. Press and hold for 3 seconds the button on the wall control that has the icon of a padlock on it. This will unlock the opener and your remotes will work. If when you try to close the door the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. One of the small lights on the sensor may be flickering ever so slightly. Tweak them a bit and try. If this isn't the case and the main light is not flashing you can try increasing the down force just a tad. This control is on the rear of the motor unit near where all those white wires go. Increase this just a bit and try. If this doesn't work you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor. It will cause this problem.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have to hold down keypad on wall to get door to
You may have a relay faulty or the wiring is connected wrong.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, with out hold down on button.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a sears craftmen garage door and the control switch on the wall light keeps flashing and I need to know how to get it toa solid light and when I press the button to close the door it goes few...
When the door reverses to the open position and the main light flashes 10 times it is a door sensor problem. Usually the sensors get bumped and need to be tweaked so that they are once again pointed at one another. Each sensor has a small light that must be on for them to work. The light on one sensor stays lit all the time and the other sensor light is only on when they are pointed at one another.
The flashing light in your wall control is a separate problem. One of the buttons on the wall control has an icon of a lock. Press and hold it for 3 seconds and release. It should stop flashing.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
217 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
