Question about HP Photosmart C7280 Printer
I'm unable to send to certain international fax machines from the US. It tries to connect for a minute or two and then fails.
    Guru:
  • 224 Answers
Awrite please follow the link that I have provided.
Copy and paste it in the address bar of your web browser and then follow the instructions that should resolve your issue.
::::::::::::::::::Cannot send faxes::::::::::::::::
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01668004&cc=us&lc=en&dlc=en&product=3204785
:::::::::::::: Fax Setup ::::::::::::::::::::
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01118192&cc=us&lc=en&dlc=en&product=3204785
:::::::::::::: Faxing With VOIP::::::::::::::::
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01079626&cc=us&lc=en&dlc=en&product=3204785
Posted on Jun 16, 2009
Error 388 when trying to send a fax
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Dec 17, 2010 | HP Photosmart C7250 All-In-One Thermal...
Sending an International Fax
definitely there is a setting which should be changed in order to send fax
Jun 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
Brother Fax 2910 Connection Problem
It's a problem with your long distance carrier
Jun 28, 2010 | Brother IntelliFax-2920 Fax
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Unable to send a fax through i-Sensys 4140
u have to do this write your number on the lcd then press start
Mar 13, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Mar 20, 2007 | Toshiba e-Studio 350 Copier
HP Photosmart C7280 Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
