Question about Kenmore 44932 Front Load Washer
What is the F05 error code for on my Kenmore elite he 4t washer
F05 error code on my Kenmore elite washer a few after it begins?
  • 15,935 Answers
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
How does the NTC Sensor on my Kenmore Elite HE 4t come out?
Turn it, then it just pulls out. It just slides into a rubber washer. Wet it with water easy the slide.
Nov 09, 2012 | Washing Machines
What does F-11 error code mean on my Kenmore HE 4t front loader washer?
I believe it means motor control unit failure. Make sure nothing is plugged into same circuit unplug unit for 10 min. and try again . If it still does not work you will need a tech
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code F05 mean on the he 4t front-loading washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
F-5 error code on Kenmore elite HE3 45872
Click on the following link for a full explanation of the "F05" error code:
This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Jun 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44932 Front Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
