Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Sony Grand WEGA KF42WE610 42" turns on and off
Hi i have a Sony Grand WEGA KF42WE610 42" and when i try and use it the screen/sound turns on and off every 30 or so seconds what could be worng?
    Scholar:
  • 89 Answers
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Posted on Jun 17, 2009
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Grand Wega turns off and comes back on
sounds like your lamp is getting weak, you need to replace it.
Jan 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Mar 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand Wega KDF-E050A10
Jkae it sounds like your hdmi tuner, I had the same problem on mine and thats what it was most likely your's went out like mine.
Hope this helps good luck
Oct 30, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
262 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
