Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a yth2448t I need a new part that the blade attatches to and dont know what it is called ?mandrel
  • 10,865 Answers
The part you need is the spindle assembly.
Posted on Jun 16, 2009
It is called a spindle. The cost including taxes is about 30 bucks. Just ordered 2 of them will be in on Monday
Posted on Jun 24, 2009
Tip
Riding Lawnmower mandrels.
There is something to be said for being frugal and only replacing a failed part. But when you have 2 or 3 blade mandrels you are replacing a mass produced part with another that looks identical.` Later another identical part fails and you do not know which mandrel was replaced earlier.
You need to mark each replacement mandrel in a way that does not wear off. Painting the new part is not a lasting method. You can place a notch in a cooling fin or drill a small hole in a cooling fin to identify the newer part.
on Sep 17, 2015 | Miscellaneous
I have a Craftsman LT 2000. I ran over a dog chain and now the blade is loose. It rattles loudly if I engage the blade. Everything seems intact and tight except the blade itself. Any advice would be...
If the bolt holding the blades on is tight, then you will need to remove the deck and remove the blade to inspect the five pointed star on the bottom of mandrel (that is what sears calls it, other manuf. call it a spindle) . If this is damaged you will need to replace the mandrel. They run a little over sixty dollars.
I hope this is helpful.
Aug 30, 2011 | Garden
I think that I over tightened the lock nut on one side (not using a tort wrench) after changing the mowing blades. I don't think it is cutting now. When I take the blades off from cutting, one blade...
there is a star shaped, or other, pattern on the bottom of the mandrel which fixes it into the blade. this has stripped so the blade is freewheeling on the mandrel. if you cannot remove the blade bolt, I think you are going to have to remove the deck and take it to a fabrication or machine shop to have them remove the blade from the mandrel. then you buy a new mandrel and a new blade, at a small engine repair shop, put it back together. take a picture of the top of the deck before you remove the deck belt so you know how to put it back on after you have the new mandrel bolted in. if it is old you may just want to replace all the mandrels while you are at it. they are less than 50 bucks each.
Aug 24, 2011 | Toro Garden
I have a dual blade deck on a Craftman's 15.5 OHC rider mower that needs to be greased. The blades make a loud racket when they are engaged. Any idea where to grease the mowing deck?
look closely and you will see the blades under the deck are physically bolted to the same gizmos which are spun by a belt on top the deck. these gizmos are called mandrels, and that is where the lube has to go. sometimes the top of the mandrel has a grease fitting and you may have to pull the deck safety shields off to get to them, and sometimes there are grease fittings on the bottom of the mandrels and you have to pull the deck off and turn it over to get to them. Then sometimes they are "lubed for life" with no grease fittings and you have to go to a small engine repair shop and buy new ones. if you get the deck belt off and there is any slop in the mandrel, then you are too late for grease and new mandrels are in order. they cost less than 50 bucks apiece. generally remove the deck, the blades, the belt, the pulleys, and a few bolts and nuts and reinstall new in reverse order. replace all the belts while you are at it.
Aug 07, 2011 | Craftsman Garden
I think I hit a hidden tree root and there is nowa terrible noise from the blades. The one blade (RHS) seems loose and I just do not know what to do to tighten it. Can you help please.
The blade attaches to the bottom of the mandrel, which has a pulley on top driven by the deck belt, and there is a part in there which failed when the immoveable object met the irresistable force. So you may well have to take the deck off, remove and replace the mandrel, or a key on the bottom of the mandrel or buy a new blade. In any there is not a quick fix for this situation, some mechanical repair work has to be done.
Aug 09, 2010 | Garden
Cutting blade barring ***
I think that part is called a mandrel, pulley on top and blade on the bottom.
Generally you remove the deck, take off the deck belt, take off the covers, take off the blade, remove the bolts holding the mandrel to the deck. Get a new mandrel at a sears store or small engine repair shop and reassemble in reverse order. May want to do them all while you are at it and save yourself duplication of work next year.
Jun 04, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blades making a bad noise
Well I would say you have a bent blade, a blade has a loose connection to the bottom of the mandrel, or a mandrel bearing is going out. Visual inspection will reveal much, just look under the deck. A bad mandrel may appear to have "runout" when viewed from the top while spinning as contrasted with a good mandrel. Viewing the one in the center while deck is working is going to be a challenge. If you decide to replace a mandrel, do yourself a favor and take a picture of the deck belt before you take it off so you know how it goes back on.
Jun 03, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
272 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
