Question about Sony Playstation 3 (PS3) Console
Help! where do i get the code to put in my ps3 for wireless connection?
    Problem Solver:
  • 13 Answers
There is no code unless someone has the password find it out and then put it in and it sould work
Posted on Jun 16, 2009
I have recently added a laptop to my wireless internet which my ps3 runs off also. I haven't had any problems conneting to the internet until I added the laptop, now it doesn't want to connect. I went...
the wep key as it is commonly referred to, ( ~10 digit letters and numbers not cap sensitive) is a passcode to gain access to a internet through the wireless router only things i can think of are A. you put it in for your console along time ago and don't remember putting it in B. you changed the setting of wireless router to get it to work for laptop C. your stealing someone's internet and they decided to add a passcode to get in it
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
How do I connect my ps3 to the internet and tv so as to view the net on tv?
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
Need help with wlan code
Security Code is configued in Wireless Router itself.
Please open your Wireless router Admin Panel in Internet Explorer. Please follow this steps.
1. Open Internet Explorer and type : http://192.168.x.x and press enter (x is router IP. Generally its 1.1 or 0.1)
2. Go to Wireless Security Tab and look there for Security code.
Now type that Security code in your Ps3 .
You find all details regarding to access router in internet explorer from Product Manual. (you can download product manual from Manufacturer site)
Mar 22, 2010 | Belkin (F5D7230-4) Router (587009)
Hello, Can you tell me how I set up my internet wireless connection please. I have tried using the step by step guide in the manual but without success. When It asks you to enter the wep code it tell me no...
are you putting in the password for the wireless internet
make sure that the password that you enter in the ps3 internet settings is the same password for the wireless router
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
My ps3 would connect to the internet
Try connecting to your router with a cable and see if that is able to get you online.
If it does, then 9/10 its a signal problem.
If it doesn't, then you have a settings problem.
Also, is your router close enough to the ps3 to supply sufficient signal to the console? From my experience, the router needs to be pretty close to the ps3 for it to get a good signal or if you have a wireless N type router. Wireless b/g routers usually need to be very close to their source for it to be fully effective as the ps3 requires.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
Can not coneect wireless router to ps3
If you received an error code, that's probably an incorrect wireless password. To verify the wireless password, open the router's admin page using IE and look for wireless security. If you are sure about your password, try to change the wireless channel of your router to channel 11 and power cycle your router by turning it off for 30 seconds then turn it back on.
Apr 15, 2009 | Belkin (F5D7230-4) Router (587009)
I want to connect my ps3 to the internet. I have a wireless connection on my desktop computer at home. I have a wireless card for my connection. Wireless service is from Alltel. Could you please help me to...
Hi there.. I set up my ps3 wireless connection up just now its quite easy really.. All you do is go to
1. Network Settings
2. Internet Connection Settings
3. Select a setting method
4. Click EASY *note this may take cpl mins*
5. two options are on the table Wired connection or Wireless
6 Click WIRELESS
7. Click on your internet name that appears if it is the one you have
8. WLAN SECURITY SETTINGS.. I usualy put None HIT X to continue
9. Now you should be all set its going to confirm your internet is set up and running properly
10. Now enjoy your online ps3 gaming!
Best of luck and hope that helped out!
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 security code
The security code, that is called network key, is stored inside the router.
Check your router manual, it will tell you how to connect to the router using Internet Explorer.
You put router IP number on Internet explorer bar and open router control panel, then you go into wireless settings, and there you find the key.
Sep 08, 2008 | Sony Playstation 3 (PS3) Console
PS3 WIRELESS CONNECTION
This code (80711008) is not reffered error code list
Try first to establish a success connection at a nearer distance. Your signal strength might not be strong enough to have a lasting connection
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
