Question about Zonet : ZFS3008P 8-port 10/100Mbps Ethernet Switch W/Plastic Housing (NEZOSW10)
Only 1 PC will work at a time on this router,
Does this router require IP addresses to be loaded in a security page?
  • jeffellett Jun 16, 2009
    The model is ZFS3008P 8 port model.
  • 331 Answers
No.... Can I be of some assistance. I need the model number and manufacture of your router
Posted on Jun 16, 2009
  • Raymond Ramirez
    Raymond Ramirez Jun 16, 2009
    zonet... ok how PC savy are you.... can we get on instant messaging?
    this will take a few minutes if we do it that way
Where is the WEP/WPA code on a Netgear router
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
Feb 04, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I disabled my smc wireless through the ip address provided. When I went to reable it, the ip page won't load?? Help please
You might be connecting through wireless before and now that you have disabled it, your computer is not connected to the router and that is why you are not able to display the setup page. You can use an Ethernet cable to connect your pc to the router. Once connected, try to load the router's setup page again through the provided ip address. If you are unsure about your router's ip address, check this out for guidance. click here.
Hope this helps.
Jun 27, 2011 | Computers & Internet
How to set my wireless into private ?
You can make the network secure putting a password with it. You need to access the Wireless Settings Page of the router. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is password. Go to the Wireless Settings Page, Under Wireless Security Mode you can select either WEP,WPA or WPA2. Then Personalize your Network Key. The Network Key serves as a password on your network to make it secure.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 03, 2011 | NetGear WGR614 Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Mar 12, 2010 | Encore ENHWI-G2 Router
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
LOST DISC AND FORGOT HOW TO SECURE NETWORK
To secure a network, you need to log into the router. Insert the router IP address in address bar and then type in router username/password to access the Settings page of router. You'd be concerned with the Security or Wireless Security page.
Jun 02, 2008 | Computers & Internet
Belkin n1 wireless router no security!!
Check ip address of your pc. Go to DOS Prompt, type ipconfig then click enter. Look for DEFAULT GATEWAY(that will be your router ip address). Open your browser and type the default gateway on the address field(example: 192.168.1.1). That will take you to your router page. You can set up security there.
Mar 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Computers & Internet Logo
94 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
