Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
My 40"samsung LCD turns on/off 3-4 times before staying on
When you turn the tv on it clicks on and off 3-4 times before finally turning on and staying on.
  • tdlynch Jun 17, 2009
    not so handy with the solder iron... not my husband either! Is this an in-home repair or would I expect to bring this in to a shop and how much should it be? Any ideas are so appreciated! Thank you for answering!
    Problem Solver:
  • 6 Answers
You need to change the 1000uf caps in the power supply. only if you are handy with a soldering iron. Take back of remove psu. You will see them bulging at the top. Think there is 5 to change :)
Posted on Jun 17, 2009
  • mjjtus Jun 19, 2009
    It depends where you take it. A lot of places now will not do board repairs and would just replace the whole psu board. I have had a look and a new psu is £114.93 just for the part trade. Any decent repair shop should be able to do it. As the parts to fix it dont really cost much I would have thought about 60-80 to get it fixed. But Most will prob say needs new psu £200
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
When I turn the TV on it clicks 10-12 times and finally turns on.
Sounds like you have bad capacitors in the power supply. If you look they will have a bulg on the top, replace them and you should be ok.
Feb 15, 2010 | Samsung LN-T4053H 40 in. LCD Television
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung le32r74bdx 32
i have a $1256 samsung 40'' lcd i have had it for about 1.5 years..just long enough for the warranty to expire..i went to turn the tv on like nomal but all i got was a ed blinking light..and than it would go out after the relay inside clicked a few times.tryed all the to fix it my self..new power cord,diffrent outlet,letting it sit unpluged for 24hrs.ect..finally i took it off the wall took the back off to see if any fusses were blown out. nothing it all looked good to me.so i took my air commpeser to it and blew the whole thing out..put it all back together..and it turned on red light was off and just a hint of light at the edge of the screen...so i was like ok and began to play my ps3 and after about 45 min i just shut off ..nothin would work back to the blinking ed light.i have not messed with it for 3 weeks and yesterday tryed it again.nothin but relay click and red light...so i hit my tv at the bottom by the switch and i came on...i couldnt believe my eyes..it was short lived after watching it for 5 hrs tuned it off and went to bed...in the morning i ran down stairs to turn on my tv..but yet again black..i was not going to spend $300 to $700 to get it fixed..so to day i got my air commpeser and blew it out again..this time i was messing with the power cord right where is hooks to the tv and the red light stayed on solid like it was in stand-by so i pressed the power button and it turned on..so long story..check the power cord and blow out you tv.."but be carful"
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
1,115 people viewed this question
Jerry Greenberg
Jerry Greenberg
