Question about Nikon COOLPIX S200 Digital Camera
My digital screen says "Memory Card is write protected" what does this mean?
    Novelist:
  • 107 Answers
When memry card is write protected, you can not write (save) anything on it. There is a tiny botton which is set to write protect to prevent the content of the memory be written over. When you write over another file (picture) the old one will be destroyed.
If you would like to write to your memory, you have take out the memory and move the botton to other side of the write protect and insert it back in your camera. Now you can take picturs and save them on the memory stick.
You would want to write protect if you do not want accidently replace an old stored picture with the new one.
I hop it helped you
Posted on Jun 16, 2009
    Sergeant:
  • 246 Answers
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: memory card is write protected
Read the Manual[a more comprehensive version is on the CD in PDF format] to cgheck out the applcation of card protection. Every camera system is different but will be documented in its manual
Posted on Sep 10, 2007
  • 121 Answers
there should be a little tab on the edge of the card with a open /closed padlock next to it the padlock is not usually there on the cheaper cards i think up (awat from the brass connector) is unlocked and down is locked
Posted on Oct 28, 2009
Testimonial: "Great,that worked. Thanks"
"memory card is write protected " on the screen. How to remove it.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 26, 2014 | Nikon COOLPIX Cameras
I have Panasonic DMC-ZS6 Lumix w/4gb memory card - has worked fine until today- now window says
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
When I turn it on it beeps and the screen says protected card, what does this mean
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 01, 2011 | Fuji FinePix A805 Digital Camera
My panasonic lumix has a message across the screen that say "This memory card is blocked" How do I get it to go off?
Usually Lumix says "This memory card is protected" when it means that the card has been locked with the little switch on the card (SD card). The message you report may mean something else.
Dec 14, 2010 | Panasonic Cameras
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"Memory card is locked
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
"Memory card requires formatting"
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Nikon COOLPIX S200 Digital Camera Logo
238 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
