Question about Whirlpool Duet GHW9150P Front Load Washer
Error code f11 washer won't wash
Error code f11
    President:
  • 1,197 Answers
I believe EVERY machine will have this F11 error eventually. Here is what fixed mine. Remove the top cover by removing the three 7mm screws on the back of the machine at the top. Slide the cover to the rear and lift off. The CCU board has 2 relays on it. They have white plastic covers. One is labeled K4 and I believe the other is K2. There are five legs on each relay soldering them to the circuit board. Remove the circuit board from the machine. It is the one you can see with the top off in the back of the machine. Unplug all the connectors. Unsolder the 2 relays...brand name Omron. With a jewelers screwdriver carefully remove the plastic cover on the K4 relay. Examine the contact points on the normally open contacts and I will guarantee they will look dull and burnt. They should be bright and shiny. You can burnish the contact points lightly and clean them with electrical contact cleaner. If you take off the cover of the 2nd relay you will see the contact points are nice and bright and shiny. Swap the 2 relays and resolder them on the circuit board. While you have the board out, take a pencil eraser and rub it on the contact points where all the connectors slide onto the board. Spray the electrical contact cleaner to wash any residue away. Carefully reinstall the circuit board and replace the top cover. Our machine has done dozens of loads since I did this with no more problems. I expect another failure at some point when the points deteriorate on the swapped relay. At that point I will try and find replacements for both relays. The K2 relay apparently has less voltage going thru the contacts and does not fail. If you feel real comfortable, you can check the "wiping" action of the points by manually operating the relay when you have it out. I adjusted mine to give a bit more wipe on both relays. I hope this helps...it worked for me!!
Posted on Jun 16, 2009
How do I fix a F11 code on Whirlpool duet washer
Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.Aug 25, 2009
give it a try - worth unplugging and plugging back in.
Jan 29, 2018 | Whirlpool Washing Machines
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My machine shows an f11 or f14 error code and it won't work. What can I do?
    Circuit Board Medics can rebuild and upgrade the CCU to eliminate the F11 error and prevent it from happening again. Find more details at http://circuitboardmedics.com/whirlpool-f11-code/
    This video shows how to remove the CCU from the machine.
    Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    F11 error code
    The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
    Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
    The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
    Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
    Whirlpool ghw9150pwo f11 error code
    f11 Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor
    Control Unit (MCU) cannot be sent correctly.
    * Check Wire Harness connectors to the MCU, the motor, and Central
    Control Unit (CCU)
    * Check the Drive system for any worn or failed components
    * Check MCU
    * Check CCU
    * Check Motor
    Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    What does F11 code mean?
    F11 is a code that referes to communication error between the central control unit and the motor control unit. Disconnect power. Check wire harness connections to motor and control board. Check drive belt, visually inspect to see if belt is broke. Check drive motor, visually confirm motor operation. It is possible that if the belt broke it may have slung around in the cabinet and damaged or loosened the wire harness connection at the motor. Try unplugging wire harness at motor and then plug it back in securely. Hope this info has helped. Thanks, Tim.
    Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Maytag Epic giving F11 error code!
    ths.gardenweb.com/forums/load/.../msg1012004912002.html
    Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
    What does the F11 error code on my Kenmore Elite He 3t mean?
    "F11" is a serial communications error. The following link explains the possible causes and how to troubleshoot:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the error code reappears, follow the advice provided in the link. In the majority of the cases, I've experienced, it was the CCU that caused the problem.
    If you have questions, or require additional assistance, please let me know. I hope this helps you.
    Jan 22, 2009 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    232 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
