I have a minn kota endura 50 trolling motor MKJ MODEL it has play in the (prop-shaft)back & forth movement 1/2 inch atleast.....or more and theres no play in either of the bearing checked it on the armature.......replaced all seals brushes, any ensight on problem???? sign DONOVAN IN OKLAHOMA
SOURCE: Minn Kota 30 transom mount motor magnets fell out during service
Hello drummondr, please contact www.minnkotamotors.com/index.asp by E-mail attention Dave with your questions. Merry Christmas.
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
SOURCE: where to buy replacement brushes for electric
http://www.northlandmarine.com/MinnBushKit3.25.htm
SOURCE: lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
