Question about Canon PIXMA MP530 All-In-One InkJet Printer
Getting the inner cover is open message when it is closed
I changed the ink and now I am getting the message that the inner cover is open when I go to print and because of that I can not print. I have turned the unit off and unplugged it from the socket and the computer and no change.
    Sergeant:
  • 361 Answers
I think you could not adjust printer cover properly.so we get many time this type of message in practs. becuse printer sencer are attached in cover and paper fedder and another parts. while they are not connec between them . they bring that type message.....thanks
Posted on Jun 16, 2009
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
INNER COVER IS OPEN FOLLOWING CHANG IN INK
The inner door is the CD tray that is disabled in US versions.
Look right above the paper output tray and you will see a 6 inch long and 1.5 in wide tray sticking parrallel to the output tray.Flip it back up and you should be good to go.
Jun 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error message inner cover is open canon pixma mp610 printer
Had the same problem myself but discovered that I had previously moved the inside flap down when I put the ink in. I moved this back into position and bingo! (If you make sure all the covers are closed then look into the printer where the paper exits you will see the flap that moves up and down, this must be in the up position)
Dec 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Dec 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I have a Canon MP600 printer and just changed 4 of the ink tanks. Even though the inner cover is closed I keep getting the error messaage "Inner cover is open. Close the inner cover and press...
  1. Have you tried turning the printer on/off?
  2. Did you replace the cartridges with the power on or off? Most printers require you to replace them with the power on.
  3. Try replacing the new one with the old ones. Do you get the same display?
  4. On the printer, is there an alignment button?
Nov 16, 2008 | Office Equipment & Supplies
On cannon pixma mp610 printer messge on the printer says inner cover is open.close inner cover and press ok. I did that and pressed reset and still get this message. Cover is closed and I cannot get the...
try to reset the printer, power off, remove the main supply cable, leave it for 1 minute... and restart the printer...below link might be useful for more troubleshooting tips..
http://etech.maiila.com
Nov 01, 2008 | Office Equipment & Supplies
Error is inner cover is open.
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Mar 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP600 printer
sounds like the inner cover is not seating properly. so, perhaps there is something amiss inside, making that cover not latch cleanly? do a visual inspection(got one of those dental type mirrors?).
Mar 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
155 people viewed this question
old marine
old marine
