Question about Motorola Mobility HS850 Consumer Headset
Need operating manual for H685.
Can it be used totally hands free.
How to change the map size
buy a bigger GPS unit or zoom in using the plus + sign. Technology improves as does the size of units. Some also have dash cams in the back and legislation is moving to totally 'hands free' use.
Nov 10, 2016 | GPS
Lost my rules for my five alive card game
SET UP
Place one set of "A-L-I-V-E" cards (color coded) in front of each player. Set aside unused "A-L-I-V-E" cards.
Shuffle the deck.
Deal out 10 cards to each player.
Place the remainder of the deck face-down in the center of the table.
Play proceeds clockwise, starting left of dealer.
WHAT HAPPENS
Players take turns playing a card onto the discard pile.
If it is a number card, add it to the running total. If this would take the total above 21, instead of playing it, you must flip over an "A-L-I-V-E" card.
If it is a WILD card, follow the appropriate instructions.
If it is your last card, the hand is over. All other players flip over an "A-L-I-V-E" card.
DRAW: All other players must pick up 1 card from the face-down deck. Counts as 0 to the running total.
DRAW 2: All other players must pick up 2 cards from the face-down deck. Count as 0 to the runing total.
PASS ME BY: Play passes to the next player in the rotation. Count as 0 to the running total.
REVERSE: Play now proceeds in an opposite direction, left to right and vice versa. If played when only two players are left, it is treated as a PASS ME BY card. Counts as 0 to the running total.
SKIP: The next player is ignored and play proceeds to the following player. If played with only two players, the player of the card would get an immediate new turn. Counts as 0 to the running total.
=21: No matter what the total was, it is now 21. Can be played when the score is already 21, when it has no effect, but avoids a penalty.
=10: The running total is now 10.
HAND IN & RE-DEAL: All players hand their cards to the player of the card. He must shuffle all the hands, including his own and re-deal them to the players.
He does not include the face down deck or the discards. He should start dealing to his left. If new hands are unequal, bad luck. Play continues as normal, but the running total is reset to 0. If this card is the last card played from a players hand, the round is over.
BOMB: When played, all other players must immediately discard a 0. If they can't, they must flip an "A-L-I-V-E" card. Running total is reset to 0.
Note: other WILD cards with a value of 0 cannot be substituted.
WINNING
The last player with an "A-L-I-V-E" CARD face up is the winner.
ALTERNATIVE SUDDEN DEATH ENDING
As soon as one player flips all "A-L-I-V-E" cards, the game ends. The player
with the most "A-L-I-V-E" cards remaining is the winner.
If there is a tie, the tied players add the total value of the number cards
remaining in their hand. The player with the lowest total wins.
ALTERNATIVE TEAM PLAY
FOR 4 TO 6 PLAYERS. DIVIDE INTO 2 TEAMS.
Team members sit alternately around the table.
Each team uses only one set of "A-L-I-V-E" cards.
All WILD cards operate as before: For example, when playing the BOMB, your team might flip several "A-L-I-V-E" cards, if the players don't have a "0".
When a player plays his last card, the opposing team loses only one life.
Play continues as normal until a team flips all "A-L-I-V-E" cards.
Apr 11, 2014 | Games
I have a paper jam in the cutting bar. I have reversed it but still can't free it. Can you help?
When you say you can't free it...does that mean the shredder wont turn in fwd or reverse,???
If it is totally siezed then you only course of action may be to take it apart and manually turn things by hand to clear the jammed paper.
Dec 13, 2010 | Royal VF1000MX Shredder
How can i prevent my computer from being infected with virus? is AVG Anti virus useful?
i dont think so , i suggest u to use india anti viru software i am using it it is not so costly and it works .....or contect me 9713767672 .......
Apr 26, 2010 | Microsoft Windows XP Professional
When you change the oil, how do you reset the computer so that it STOPS telling you to change the oil??
Hello there :
The easiest way to do this is to take the vehical to autozone and have them use the hand held diagnostic machine and they will clear the alarm for you amnd it is totally free just tell them what you want done ok
I use them a lot for all of the vehicals i service
Hope this is very helpful
Best regards Michael
Jan 14, 2010 | 2000 Jeep Grand Cherokee
I have purchased a second hand laptop. How can i
you try symantec backup and restore programs and also use a usb stick or try totalcommander with a network cable cross over between the 2 pcthe program are free and works with also network connections
google for total commander you wil see the page of ghisler thad the program
Dec 20, 2009 | Toshiba Tecra S1 Laptop Notebook
Kaisen P83 - Invalid Viedo File
You need "Total Video Converter" and "Xilisoft 3gp".
1st make a video with your phone. Open the file with Xilisoft 3gp.
Take note of this:
Summary:
Duration: ????
Bit rate: ????kbps
Video:
Format: mjpeg
Frame rate: ???fps
Audio:
Format: ????
Bit rate: ???kbps
Sample rate: ---
Channels: ????
Now convert a video with "Total Video Converter" using the parameters you got on Xilisoft.
I tryed and works well.
Hope this help you ^^
Jan 17, 2008 | Siemens M56 Earbud Hands Free Headset
How to know the old mobile total call time if i buy a second hand mobile
go to setting there u will find call timer in that option total incoming and outgoing calls and also the total call duration from that u may know how much time the cellular phone is used
Dec 03, 2007 | Samsung SGH-X200 Cellular Phone
Motorola Mobility HS850 Consumer Headset Logo
27 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
