Question about Network & Wireless Adapters
Laptop driver problem
The laptop is built for vista but i loaded XP so i could be able to use some programs copmatible to my work, but the problem is with XP i cant find the ethernet, VGA, Sound and pmcia drivers what should i do?
  • 1,006 Answers
Re: laptop driver problem
Witch CHIPSET DO U HAVE???I will try to find the right driver for you???
Posted on Oct 31, 2007
  • 88 Answers
Contact the manufacturer of the laptop for support. They may or may not have drivers for it- but if they do they should be able to point you in the right direction. Unfortunately most manufacturers that sell vista laptops are not providing any drivers for xp, and have no plans to. Good luck!
0 characters
3 Points
I have just bought a new computer and i am trying to install my linksys adapter to my new computer. it worked fine on the old 1, but is not working on the new 1. I am wondering what could be some problems
The WUSB54GSC adapter had been out of production for a while...the last driver update was for Windows XP in 2008 (for Version 2 devices). You should carefully examine the device to see if it is Version 1 or Version 2, as this is necessary when visiting the driver page.
If you're trying to use the adapter on a Windows 7 machine, and Windows 7 does not automatically install the driver, then you're pretty much out of luck as Linksys does not supply a Windows 7 driver for this unit. They don't list a Vista driver, either, although often XP drivers will transfer to Vista without difficulty.
So...if you're trying to install it on a Vista machine, try downloading/installing the XP driver for your device MAY work. If that does not work, or if it's a Win 7 machine, time for a new adapter.
Most new computers these days (at least laptops) have wireless built-in and don't need a USB adapter. I'm assuming, therefore, that you're using this on a desktop. If so, and you need a new one, very good quality ones can be had at WalMart for around $20. Just be sure whatever you buy is compatible to your operating system. It will be printed on the packaging.
Hope that's helpful.
Jan 20, 2011 | Linksys WUSB54GSC Compact Wireless-G USB...
How to fix the wireless controler in a think pad
When you download the T40 device drivers from the IBM/Lenevo WEB site make sure you select your model laptop and, they need to be the XP or Vista versions of the drivers you need.
When you run the driver programs they will be unzipped/expanded to the hard drive in a folder c:\drivers. Then you need to open the various folders and run the setup programs to install the various drivers.
NOTE - The T40 series laptops come with various different manufacturers devices (eg. there are a few different wireless model LANs) and if one version driver doesn't work you need to install a different one. It is a bit of trial and error to find the right one
Jul 22, 2009 | Network & Wireless Adapters
Drivers instalation
You can down load the driver for windows XP from the following link.
Download RealTek RTL8111C Auto installation program v.702 driver
For windows vista
Click here
Download RealTek RTL8111C Driver v.6.208
Good luck
If my solution proves useful please rate it.
Mar 27, 2009 | Network & Wireless Adapters
Acer extensa 4420
Well, I did the same thing, replaced vista with XP Pro, and couldnt get the wireless to work (the xp runs incredibly faster on this machine, B.T.W).
After days and days of trying to figure out this same problem, I finally found the driver. I found it at gateway...the link is here...
Hope this helps all of you who did the same!
Oct 02, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Can connect with usb stick on one PC and through inbuilt wireless on a laptop to the main router but not a new one
becos of you using three different os one is xp,other one is vista and other on is xpsp3 all the driver is different so how can he connect it.
Sep 06, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Broadcom wireless 802.11g driver
Unfortunately there are no drivers for XP for your Vista equipment. It was intentionally designed to only work in the vista environment. This is Microsoft's way of strong arming people to migrate to vista against their will! They threaten the hardware manufacturers to pull licensing rights if they release XP drivers for the new equipment. You can buy an external wifi adapter, but then you have to deal with a device hanging out the side of your laptop and using up one of your usb sockets. This is the only way to get around it for the time being. The hackers are slowly writing the drivers, but there are so many different versions of equipment odds are slim that they will ever write one for your exact wifi card. I will place you on my update list and contact you if/when I find the hacked driver for you. I'm keeping a data base of 100's of people going through your exact problem. Complain vigorously to microsoft through email and tell them how you feel about them forcing you to migrate to an operating system nobody wants or needs. If enough people do maybe they will get the picture and allow the hardware manufacturers to release XP drivers. I hope you found this helpful and informative. If you want to be on my update list send me an email to and I will add you to my list, make sure to include your make and model laptop so I do not have to search through here for it,Thanks. As soon as I find a Verified driver that works with your system I will send you a link where you can download it from my personal server. Hope to hear from you soon,
Aug 30, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Acer 4315 WLAN driver for WIndows XP
Sorry if I am coming into this early, but I had the same problem with my Acer Extensa 4420. Eventually, after tons of forum threads, I found that the same chip that's in the Acer computers is also in some Dell computers. Just ignore the fact that it says it's by Dell and download this:
Then, extract the files to a folder and from device manager, and point 'Network Controller' (or whatever your wireless adapter is named in device manager) to that folder.
Aug 04, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Hi, George here I am E-mailing you the driver for your wireless card. Hopefully this gets you going. Make sure to rate me fixya if this works. If gmail does not let you download the file I will send it to you through yahoo messenger direct file transfer. My yahoo name is geokohler007. Hope this helps get you going.
Jul 20, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Wirless driver
check to see if your drivers are working you may need to reinstall
Jan 16, 2008 | Panasonic (ET-CDWL1) 802.11b Wireless...
Network & Wireless Adapters Logo
146 people viewed this question
Top Network & Wireless Adapters Experts
 C. Dante
C. Dante
Are you a Network and Wireless Adapter Expert? Answer questions, earn points and help others
