Ups does not work on home generator
Hi
i just bought a APC back-ups Es 500v(BE 500y-IN)
it does not get charged or work on the home generator.
i stay in a small town in india and state electricity is very scarce an infrequent so we depend mostly in home generatoras.
i asked the service guy and he said may be the generator frequency is too low.
is there any device to get the right frequency or is there any thing i can try
please advice
As a Ups manufacturer, I suggest the following: check the output frequency of the generator, it shout be 60hz +/- .5hz
Posted on Nov 02, 2007
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Your generator is the problem, ups's usaully work from 90volts-125volts and the frequency needs to be steady, any lower or higher and it will not charge. it is a safety protocol with in the ups cpu.
I know of a voltage regulator for generators that would make the voltage consistant and even and that would cure your problem.
here is a example website: http://www.partsfortechs.com/asapcart/3001540a-replacement-voltage-regulator-for-onan-p-1.html
Posted on Nov 01, 2007
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My APC BE500U keeps resetting
It certainly indictes a problem with the APC unit a replacement bettry may or may not solve the problem. Do you really need one as you have an anti surge protector?
Sep 18, 2009 | APC 500VA BE500U Back-UPS ES...
Ups not working on generator power
you will try to change the fuse in ups
Aug 24, 2009 | APC Back-UPS CS 500VA UPS System
Need charging instructions for apc back-ups es 350
Take off the bottom cover and make sure the battery is connected (both terminals).
Plug the unit into a wall outlet.
Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
Done.
Aug 08, 2009 | APC Back-UPS ES 350 UPS System
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
May 27, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Computers & Internet Logo
752 people viewed this question
David Payne
David Payne
