Question about Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car Video Player
Where does the yellow wire go from the brain - Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car Video Player
  • 15,935 Answers
CLICK HERE for the installation manual
Yellow wire must be connected to a CONSTANT 12V source wire.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 16, 2009
1997 dodge neon stopped running while driving replaced sensors egr, plugs. wires, solenoid, brain cleaned injectors. getting gas don't no what else to do.
Try ignition coils, are you getting fire to the plugs? If you the spark is a weak yellow that may be your problem.
Oct 03, 2013 | Dodge Neon Cars & Trucks
I have kenwood excelon ddx 7015 unit powers up but says a cord is not pluged in. Wanted to know if this unit has a internal or external brain box and if it has an external brainbox how do i find one
I have a DDX7015, and can tell you that the unit is completely self-contained. You can get a kds-p901 external 5.1 processing unit that deactivates the on-board processing brain; the 901 connects via fiber optic.
It sounds like your constant power (yellow) is not energizing. You can test that pretty easy - you should be able to hit the eject button with the car turned off, and the faceplate should lower.
Try pulling the unit out and checking the in-line fuses and the wires - you may find that the wires got crushed during installation. To test functionality, you can try twisting both red and yellow together, and connecting it directly to the battery. You may find that your 'constant power' in your dash is unable to supply the current this head unit needs (7-10A, if I remember correctly). If that's the case, you may need to run a dedicated wire out to the battery for the yellow. Make sure you put a fuse close to the battery. The fuse is not to protect the head unit, but to keep the wire from burning up in the event it gets shorted, so the fuse can be 20A or so (the head unit should have its own fuse). I hope your head unit comes to life - I've had 6 years of great service from mine, and it plays mp3s and wmas directly off of a data DVD, and works great with the KNA-DV4100 navigation system.
Sep 04, 2010 | Car Audio & Video
I need the head unit for a kvt 915. or i got the wiring for it, for sale, wires and brain unit.
Try ebay, some time you can find junk yards that has face plate, or other parts. hope this was helpfull
May 13, 2010 | Kenwood Excelon KVT-915DVD Car DVD Player
How to install a iva-d310 from alpine
The yellow/black wire is for the foot brake and the yellow/blue is for the parking break. These wires need to be hooked up in line with the pinch connectors to the correct wire. The yellow/black wire needs to hook up to the wire to the foot break lead wire before the switch and the yellow/blue needs to hook up to the lead wire before the parking brake switch. This is a sefty feature to deactivate the video display because it is illegal to have video in the view of the driver while the vehicle is moving. These wires are used to tell if the car is stopped.
Dec 06, 2009 | Alpine IVA-D310 Car DVD Player
Pioneer AVIC-N3. What wires power it on??
the pioneer avic n3 has a seperate brain system and there is a cable that hooks the two together its called like the 13 pin wire or something and once you hook the brain and the head unit together it will have the display and everything else
May 25, 2009 | Pioneer AVIC-N2 Car DVD Player
There was an old security system in my truck prior to me buying it and ive had it for six months and today i tried to start it and it wouldnt even make a noise turnig the ignition except for the radio and...
is the alarm factory or aftermarket?
If aftermarket - the brain will be under the dash attached somewhere near the steering column.
Look for an 10 or 12 Gauge YELLOW wire that has been cut.
This is your starter wire.
one half goes in one side of the brain, and the other comes out the other side.
either solder or use crimp-connectors to return this yellow wire back to factory.
If you no longer require the alarm - you can do the same for every other wire on the brain.
Here is the color code chart for your vehicle...
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White Coil
Brake Switch White Brake Switch
Trunk Release Brown Switch or Driver's Kick Panel
Trunk Pin DIESEL- Glow Connector Blue behind Instrument Cluster
Parking Lights Brown (+) Light Switch
Head Lamp Yellow (+) Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Purple (-) 4 Pin Black Connector Driver's Kick Panel
Door Lock Light Blue Driver's Kick Panel w/Keyless Positive
Door Unlock White W/o Keyless Entry Reverse Polarity (5 Wire)
Horn Wire Black (-) Steering Column
Windows Up LF=Blue, RF=Light Blue
Windows Down LF=Brown, RF=Tan
Apr 26, 2009 | 1995 GMC Sierra C1500
Want to watch dvd without being parked
The easiest way to do this is buy a PAC-7 to wire in onto your brain. This item costs $20 bucks off of ebay. If you dont want to spend that you could get a toggle switch and wire that in because in order to get that to work you have to switch the toggle 3 time to get this to work. The Pac does the switching ineternally giving you a seamless view.
Sep 19, 2008 | Alpine IVA-D310 Car DVD Player
Kenwood KVT911
kvt 911 screen does not pop up you have to manually flip it once it's deployed out.
Aug 28, 2008 | Car Audio & Video
Blowing fuses
you may have the rem wire hooked up to the yellow 12v battery wire located on your harness. try yellow to yellow and if your rem is not working correctly when is hooked blue to blue put in on the red ignition wire located on your harness. should solve the problem. or return it
Mar 02, 2008 | AudioControl KVT-911DVD Car Video Player
Avh-p6400cd indash radio
With this specific Pioneer model you need a brain for it ti function. You will be spending a good amount of money on all of the cords and brain. If you would like to do that, go to www.pioneerelectronics.com and type in your model number. every cord and accessory you will need will be listed there. This specific model has an optional navigation and tv tuner. Also for RCA outputs you will need another harness.
Dec 23, 2007 | Pioneer AVH-P6400CD Car DVD Player
Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car Video Player Logo
110 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
