19'' LCD White westinghouse monitor was going off and on at random
And finally went off and will not come back on now.
  • 1,684 Answers
You have a very common problem in these monitors. The power supply has died. If you are comfortable disassembling your monitor and replacing/soldering parts I can give you directions. If you don't want to try yourself we offer repair services. We can repair your LCD for $30 plus return shipping to you. If you are interested in either directions or repair please contact me at buddy@ccl-la.com
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Hello i have a 19'' white westinghouse lcd computer monitor and it all white, is there anything i can do, i have already checked the green board and capacitators and what not and eveything tested fine, is...
chapp29, You didn't tell me the brand name of the electrolytic filter capacitors that are on your monitors "switch-mode-power-supply / cold-cathode-fluorescent-lamp-ballast" circuit board. How did you measure (check) the capacitors? Are any of the rubber seals pushed out of the bottom of any capacitors? What is the "date of manufacture" of this unit? Will L1916HW work connected to a different "known-good" pc? Will "known-good" monitor work ok when connected to your pc? 12fixlouie
Sep 15, 2010 | Westinghouse Electric L1916HW 19" Monitor
Westinghouse keeps shutting off randomly
Power supply board finally dies.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Apr 17, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Screen goes black with power on. It also flickers and power flickers. Does both randomly. New computer. All new drivers. Windows 7. Video card and monitor set with same display settings.
This sounds like a power issue. Check the power cord going to the monitor. Make sure it is fully plugged in. Make sure the receptacle is good and the wiring at that receptacle is tight and secure. Try another receptacle to be sure. Make sure the cord going from the computer to the monitor is secure and tight. You say this is a new computer. If so, then take it back where you bought it if you cannot find the problem.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Monitor stays white, cannot get picture
U might have problem with ur VGA cable. It may be loosely plugged. Plug it tight
Jun 24, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Backlight out
hi..The board that drives the backlights might be defective
and board will need to be replaced.
check it out..
thank u..
kindly rate my response..
May 06, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Audio and picture quit working on white westinghouse lcm-17v8
If you haven't figured it out yet through a web search, Westinghouse monitoris have problems with blown caps on the power supply board. If you are lucky the problem is minimal and won't require more than replacement of the caps. You won't know until/unless you open the case and inspect the power supply board.
Dec 23, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse LCM22w2 Monitor
I'll buy it from you. I just need a non-cracked LCD from this monitor. It doesn't even need to turn on. You can e-mail me at rallis@gmail.com
Jan 30, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
470 people viewed this question
Alun Cox
David Payne
David Payne
