Question about Mitsubishi VS-45603 45" Rear Projection Television
Mitsubishi projection vs-4551C no picture but sound ok
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
  • 1153 Answers
SOURCE: mitsubishi model vs-5043
1. CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB.
Posted on Aug 26, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source. One of this will be your problem! Let me know.
Posted on Oct 09, 2007
Slinteriors
  • 8617 Answers
SOURCE: my mitsubishi vs 5071
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Posted on Jan 26, 2008
premtech
  • 934 Answers
SOURCE: Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Posted on Sep 10, 2008
Vs 50703 mitsubishi power led comes on solid no picture no sound
Press menu on the remote to check picture. if ok, check signal source(eg. dvd, cable etc). Press input or device and menu button in the front panel at the same time to get error code.
Dec 29, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Why does my sound come on but no picture, then picture after several minutes?Mitsubishi vs-6047
it sounds like a component is going bad. i have known a flyback transformer to act like this before going out
Nov 10, 2009 | Mitsubishi VS-6047 60" Rear Projection...
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-6041
wondering if you still have this i would like to buy it from you and wher u are locatred
Nov 08, 2006 | Mitsubishi VS-6041 60" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
