Question about Whirlpool GD2SHGX Refrigerator
Fridge and freezer not working .very weak. only 5 years old
  • chris weier May 11, 2010
    is there frost on the back of the freezer section? indicates a defrost problem. is the fan running? is the compressor running?
  • Whirlpool Master
  • 4,655 Answers
First I want you to unplug the refrigerator and open the control panel inside the fresh food compartment. Inside there is a part called a defrost timer but its electronic. Part number 4388932
This is most likely your problem with the refrigerator. Its not defrosting. When you are working and power is unplugged I want you to check the defrost heater and have a look at the defrost thermostat inside the back wall of the freezer. Take one wire off the end of one side of the defrost element and check to see if there is continuity. The defrost thermostat could also be a problem but when the temperature in the back of freezer reaches 50 degrees the defrost thermostat will have the contacts open. That is normal at that temp. When not normal is when its freezing and the contacts are open. That will cause the freezer to miss defrost. Check these things, check for burn marks on the defrost control board and let me know what you find. Why this post is so late I will never know. Sorry I just noticed the date. Maybe this will help someone..Sea Breeze
Posted on Jun 21, 2009
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Compressor will not come on.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
I have a 4 year old Whirlpool CB60 fridge freezer
turn your control knob to 3 and that should control the appliance....what number have you had it on???
Oct 25, 2017 | Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Freezer has bad smell, cleaned entire fridge and freezer out, no help. working fine but smells ?? side by side model about 5 years old, maytag
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Mar 31, 2009 | Hotpoint HSS25GFP Side by Side...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Whirlpool GD2SHGX Refrigerator Logo
138 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
