Question about Uniden Cordless Phone
GE28223EJ3 loses registeration every day and I have to reregister
It is possible that trucks passing about 100 feet of my home have their CB's blasting away and cause phone to switch channel.
A second problem is the loudspeaker on the back of phone stopped working on one phone at 2 months and now second phone is failing after 11 months. Am sending them back under warranty.
Will I have same problem with replacement?
  • 58 Answers
With the cb´s you may,because you may have the 2,4 hz phone
Posted on Sep 16, 2009
1999 Nissan Pathfinder won't start.
if engine management light lit up on dashboard you will need an obd scanner that then gives you the code to what is wrong.
Dec 26, 2016 | Nissan Cars & Trucks
Tip
Cb ranges in mileage.
I have experimented for many years with various antennas and gain in the frequencies 26.965 to 27.405mhz. I have found that best performances on the Citizens Band is upper channels 37 or 39. This is where the band gets quieter and more close to Fm type communicating. Performance in antenna and hearing is best here. The Antron A99 sitting just 15 feet will get you 50 miles with decent results on a cheap Cobra 19plus or Cobra 21LTD. I can tell you by fact that a Cobra 21Ltd is equal to Cobra 25Ltd's(don't let noone tell you different) Its the same board, same calibration, same wattage plus its about $15 or so dollars cheaper than. Antennas have to be set for your frequency. I have found that the 8.5 ft(102 inch) steel whip performs best at approximate Channel #37 to 40. Homemade antennas built with a 8.25 ft element and 2 8foot rods down the side(ground) with a rod crossing the bottom at 1.5 feet. In the shape of a womans skirt.( Do not let the ground "skirt" touch the pole,seperate it by plastic PVC or milk jug with trash bag ties) I got 50 to 60 miles with this homemade job I would say had a DB gain of 10dbi. I have built home antennas that outperform Antrons. To be safe though and quick to setup is Antron A99 for about $65. Antrons have already set the frequency and low SWR. !!!DO NOT TUNE ANTRON A99 - IT BREAKS INTERNALLY!!! The average range one can get is say 10 to 50 miles average(best at night 10pm to 3 am) Don't expect any better with a Superior radio and tower or linear. A linear may kick hard within 25 miles but after that it fades into low in the distance. Unless you use 10 kilowatt or 25 Kilowatts(Electric bill will increase by $300 more--who needs it) A good power Mic on a straight radio Cobra 21LTD or 25 Ltd will be better than any mid-size linear say up to 250 watts. Your radio itself has potential with antenna gain of equal 25 to 45 watts alone. Mathematically your best with a Super Antenna and Height above 35 feet, plus heavy grounding(chain link fence buried into earth 20 X 20 feet about 8 feet down(a rod 8ft also will work) or if possible a Junk car buried into earth 8-10 feet under your Antenna. Use heavy gauge thick LOWLOSS 50 ohm coax 95% shield less than 100 feet to achieve max power out. Lengths in coax are great at 9,18,27,36 up to 72 feet(No higher than needed) The old timers swear by 72 feet. Antenna Height say: 45 feet tower with 72 feet of Coax is the usual Base setup. FCC restricts antenna towers to 60 feet above ground. No more than 20 feet above your house somewhat(when attached to house roof). No need to put $10,000 dollars in a setup with no more range than others. A mobile radio(Tuned) with Antron A99 will about outdo all Base station radios. Hope this helps you. 73's to you all.
on May 04, 2011 | Radio Communications
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
Netgear65 n750 not effective 40 ft. away
If the router has "N" value it should run a good distance away, even to the neighbors home. If "G" 30 Feet to 50 feet max.
40 Feet is difficult if passing through thick walls or steel buildings. If it is not an "N" router, then you need that or an Extender system. See TigerDirect for hardware replaements.
Apr 15, 2014 | NetGear WGR614 Wireless Router
Honda CB 100 view manual
Hi, Anonymous the vast majority of service, parts fiche, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. If there is no $ sign after the manual link it is free to download for viewing or printing. To download your manual please click on the blue links below. Good luck and have a wonderful day
1971 HONDA 100 125 CB100 SERVICE REPAIR MANUAL Download Manuals Technical $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Honda CB 100 1971
Honda CB 100 Wikipedia
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 31, 2014 | Honda CB 100 Motorcycles
1973 Honda CB 100 wiring diagram
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1973 Honda CB 100 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda CB125S Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Aug 27, 2012 | 1973 Honda CB 100
How fast does a 1972 Honda CB 100 go @
Hi, Stallard_jak 68 mph for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda CB 100 1972
honda CB 100 speed test
Jun 18, 2012 | 1972 Honda CB 100
Why dont these reach very far??? i got an Pyramid 20cb antenna Any good??
CB radios are limited to 4 watts input to the 'final'. CB is suppose to be 'line of sight' or about 20 miles. Variables include where you are using the radio ... in the city or in the country ... signal is blocked by buildings and other environmental conditions. A full wave is 36 feet ... is your antenna some number that will multiply to 36 feet? 1/2 wave antenna = 18 feet ... max allowed in the US ... max hight is 20 feet above the mount. If you have an 'old' CB, they were limited to 5 watts to the final. On a good night, one might talk 100 miles away ... but is of course not legal.
Sep 21, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Garmin 255 misdirects me
Maybe you need an update of your GPS software
Get the Webupdater. You will see that there are some changes already.
If this doesn't work, get some other maps.
The day after I bougth my Nüvi 300, there were updatess available.
Nov 30, 2008 | Garmin nuvi 200W GPS Receiver
I had the same problem with both red lights going on..............
dear dan,
in many cases from my experience is Even brand new things have away of not always working right or being built all correctly my two suggestions for u is to take the radio back which at this point of replying may be to late Other way of doing this is if u got a local cb repair shop take it there and have then look at it.
Apr 04, 2008 | Uniden Bearcat Pro PC78LTW 40-Channels...
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
