Question about Intex 1500 Gph Swimming Pool Filter Pump Above Ground
I cannot get one of the filter valves closed
And the water drains out so I cannot fill the pool. Is the filter broken? Or something I need to do?
  • 640 Answers
Water should not be draining from your pool filter at all. There should be one hose that connects to from the filter to the pool and another hose that returns the filtered water from the filter to the pool. It is a continuous loop. If water is coming out of your pool during this process, either you don't have a hose connected properly or the hose is leaking/cracked.
Posted on Sep 13, 2010
I have a hayward sand filter pro series and for some reason the water from the pool keeps draining I need to know if the switch at the top is at the right direction
check to see if water coming out of backwash valve while if filter position bad multiport gasket you can put a valve on it and close when not backwashing
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
When I turned my fileter on this morning, there was a loud humming sound coming from the filter (not the motor). I didn't think anything of it, but a hour later, I noticed that the water level had...
The problem is definately in the backwash valve. There are two major types of valves, the push pull valve and the rotory valve. In either case if the valve is disassembled you should be able to find something wrong with it. On a push pull valve there are O-rings that could fail valve part that holds the O-rings could be broken. You can buy a replacement part or the whole valve at a pool supply store. If the valve is a rotory valve then a spider seal may be broken or the valve head could be defective. If the spider seal is bad you can glue a new one in its place but it is tricky to glue in a new one. The head can be purchased at a pool supply store. I hope this helps. If you can't get the parts immediately then you can plug the drain temporally until you need to backwash the filter or the defective parts are replaced. This is important so you pool can remain in service. I hope this helps.
Aug 12, 2011 | Pentair Fns Plus 48 sqft De Pool Filter...
I just cleaned out my Pentair FSN filter as I hve done several times before. I replaced the internal air bleed assembly from the factory piece (broken filter piece) to one with a screen from the pool...
it sounds like your valving for the return water is set wrong. check to make sure that some water will return to the spa when the pool is running. It's a valving problem more than it is a filter problem.
Aug 23, 2010 | Pentair Fns Plus 48 sqft De Pool Filter...
When I backwash or rinse my pump reservoir fills to the top when I filter I have air bubbles at pool discharge and reservoir about 3/4 full and air is evident. Do I need to start digging up my skimmer line...
When backwashing or rinsing the same water is used as in filtering.(skimmer and main drain) so I don't think skimmer damage is the issue. Check if the pool water is low at the skimmer after the backwash cycle, Also check to see if the skimmer weir gate (flapper) is stuck in the upright position. I would suggest 2 main checks. Fill the pool higher than usual, back wash, ensure the pool water level is 1/2 way up the skimmer level and try again. Also, if your lines are valved right, shut off the skimmer during the filter cycle and see what happens. Lastly, the gasket on your multi-port valve may be bad.
Jul 16, 2010 | Hayward 3/4hp Super Pump Inground Pool...
We just remodeled our pool when we filled it up about 1 month ago, the spa would empty into the pool when filter was off...my husband replaced a valve and it wasn't doing it anymore, he just cleaned the...
There are a number of reasons the water can drain back into the pool. It could be the backwash valve. It could also be an automated 3-way valve that is not fully going in the right position when it is in the pool mode. Sometimes a switch on an automated valve is in the wrong position. Some systems have a check valve that is not fully blocking flow in the reverse direction. Follow the path the water might be taking and it might help you figure out what it is. You may need to take one or more valves apart to make sure what position it is in and inspect the sealing surfaces. If you take a valve apart make sure you grease any o-rings or seating surfaces as you reassemble it. Good luck.
Aug 16, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Intex 1500 Gph Swimming Pool Filter Pump Above Ground Logo
183 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
