Question about Bethesda Softworks The Elder Scrolls IV: Oblivion Game of the Year Edition
I need help activating the Ultimate Heist.
I have just completed the quest, Boots of Springheel Jak. My independent thievery guide says I have fenced over 800 gold and should wait for Gray Fox's messenger. I have tried waiting in several cities (including the imperial city). While waiting for 2 weeks (24-hour game time) the messenger does not appear. I have also fenced over 2,000 gold in items. Any ideas on what to do? By the way, I have this game of the year edition for Xbox 360.
  • 91 Answers
At the end of the mission i recived this msg- the Gray Fox in Ganredhel's house in Cheydinhal.
Posted on Dec 16, 2009
I need password for payday the heist game rar file
To reset the rar password you shuold install a disk of rar password unlocker,it might help. Password Unlocker
Apr 27, 2014 | Sony Unit 13 Ps Vita Games Sony
Does jak 2, renegade game on play station 2 come with a booklet?
Yes it does. Click on the link below and then click on the PDF link towards the bottom right side of the page to download the Jak 2 renegade owners manual for the PlayStation 2:
http://safemanuals.com/user-guide-instructions-owner-manual/GAMES%20PS2/JAK%20II%20-%20EL%20RENEGADO-_S
Feb 04, 2011 | Sony Jak and Daxter: The Precursor Legacy...
Imate, ultimate 8502, when i started to boot, hangup at "align screen" i already tapped the screen at 4 corners, but still hangup at align screen, so pls guide me what i have to do
imate, ultimate 8502, when i started to boot, hangup at "align screen"
Jan 02, 2011 | i-mate Ultimate 8502 Cell Phone
Free download of user manual english windows 7 ultimate
Hi Steve,
Here is a downloadable pdf file titled "The Ultimate Windows 7 Guide"
windows7themes.net/win7guide.pdf
other guides can be found here:
http://gizmodo.com/5150298/windows-7-the-complete-guide
http://www.ruhanirabin.com/ultimate-performance-guide-windows-7/
http://www.ocztechnologyforum.com/forum/showthread.php?63273-*-Windows-7-Ultimate-Tweaks-amp-Utilities-*
Hope these help.
Dec 26, 2010 | Computers & Internet
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
How do I activate the 'Ultimate Heist' Quest?
these are the steps to complete the ULTIMATE HEIST quest.
  1. After fencing at least 1000 gold in stolen items, the Gray Fox will contact you for a mission.
  2. Sneak into the "Imperial Palace Basement" and activate the Glass of Time to enter the Imperial City's sewers.
  3. Make your way through "The Old Way" and "The Lost Catacombs" to the "Hall of Epochs".
  4. Sneak through the "Imperial Palace" to the "Elder Library".
  5. After receiving the Elder Scroll, escape from the "Imperial Battlemage's Room" and return to the Gray Fox.
  6. Take the ring the Gray Fox gave you to the Countess of Anvil, Millona Umbranox.
  7. After details are revealed, accept the Gray Cowl of Nocturnal to become the new Thieves Guild Guildmaster and Gray Fox.
Oct 03, 2009 | Bethesda Softworks The Elder Scrolls IV:...
Acer Aspire 5100 Stuck in eRecovery boot loop.
You are going to need a boot up partition manager likeon the Ultimate Boot CD (ultimatebootcd.com). Boot to it, go into the partition program, then set the active partition back. Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Acer Aspire 5100 Notebook
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Bethesda Softworks The Elder Scrolls IV: Oblivion Game of the Year Edition Logo
201 people viewed this question
Top Bethesda Softworks Video Game Consoles & Games Experts
Adam Jasar
Level 1 Expert
Thomas Moore
Thomas Moore
Level 1 Expert
KUSTOMBLACK GUNZ
KUSTOMBLACK GUNZ
Are you a Bethesda Softworks Video Game Console and Game Expert? Answer questions, earn points and help others
