Question about Toshiba 27A45 27" TV
Retrace lines in top of tv...
There are some retrace lines in the first 4 inches in the top of the tv. I hoped to find some adjustments on the board (chassis M3S226) and the only 2 I found didn't help. Any clues???
Thanks
  • Andre Taillefer Jun 17, 2009
    I found a chip that is a LA78041 and I have the schematic on hand. There's a few capacitors but they don't have the numbers you give. I'll need to know more about the capacitors you suggest to change so I can spot the good ones to change.
  • 2,336 Answers
These lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. The values of the capacitors are between 1uF, 10uF or possibly a 47uF.
I do not have the service manual at this moment but you can google it by the model number of your TV.
Let me know if you need further assistance.
Posted on Jun 16, 2009
  • 1 more comment
  • Jaime Hernandez Jun 16, 2009
    Check the circuit board and try to find an IC with the following markins LA7847, this IC should be mounted on a heatsink. Once you find it look for C423, C406 and C409. I could also send you a schematic from a model number 27D46 if needed.
  • Jaime Hernandez Jun 18, 2009
    The reason you do not see them is because the ones I mentioend on my previous post was from a different model.
    If you have a pdf file you could send it to me to tell you the ones to replace. My email is jah2mil@hotmail.com
  • 70 Answers
Look for c407
Posted on Apr 21, 2010
My Zenith SG2721H has thin green horizontal lines across the screen.
Most "modern" CRT TVs have automatic color biasing which means a complete of manual control. Depending on how your set is manufactured, it may have a control for each color located on the neck board for adjusting the drive to each of the CRT guns.
What you're seeing is called 'retrace' and you're correct that this has to do with color blanking. The most common issue causing 'faint' retrace is too much drive to one of the CRT guns. Hopefully, your set has an adjustment to back off the drive for the green gun. If not, this can be the result of a bad capacitor or leaky transistor in the green circuit.
If all else fails, locate the SCREEN of G2 knob on the back of the flyback transformer and back it down a touch; sometimes this is all it takes.
Dec 14, 2012 | Televison & Video
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
My sony 65 inch projetion tv has a shadowed picture. It looks like it just needs to be adjusted, how do I adjust the picture?
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Mar 03, 2009 | Sony Televison & Video
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-61HS10 with 6 blinks
Set screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Hope This Helps
Aug 19, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung 42 HCN4226wx
i think you got a bad board, ask for an exchange.
Jan 21, 2008 | Samsung HCN4226W 42" Rear Projection...
Toshiba 36A42 TV. Dim Picture
Check the "screen" control on the flyback (lower knob) its easy to hit moving a board around. Try to adjust back to its original setting. Look for where the dust is, it should be on top. Or any marks might help. Other wise adjust slowly, back off if any retrace lines appear, with user settings at there normal settings.
Oct 27, 2007 | Toshiba 27AF42 27" TV
Green arcs from bottom up with darkest one at bottom on dark screens
there is a way to get rid of the lines, you need to enter a code from your remote to access a hidden menu. From there you can adjust the lasers in the tv(green lines)I beleive it is very sensitive though, if done wrong can reck the tv. Not sure of the code or directions on how to exactly adjust the lasers, actually looking for them my self. Hope i was some help though!
Jan 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Toshiba 27A45 27" TV Logo
400 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
