Question about HP DesignJet 120nr InkJet Printer
Carriage belt fitting
How do you replace the carriage belt on a HP Designjet 120nr ?
    Problem Solver:
  • 8 Answers
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
Hp designjet 500 carriage assembly it's vibrating
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Nov 26, 2012 | HP DesignJet 500 InkJet Printer
I have an HP 120nr designjet plotter The serpentine belt that is used to move the print head carriage is worn out. I got a new belt, but I can't get the carriage off or accessable to put new belt on.
You have to remove the center cover, the right end cover, the electronics module, the power supply, the service station, the ink supplies tubes, the carriage assembly and then you can release the belt from the bottom of the carriage assembly.
Please don't do it, unless you have been trained, or have much money, or you just want to junk the printer.
Apr 09, 2011 | Office Equipment & Supplies
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Error code 221
211 Error with main PCA, ink supply station or carriage
May 25, 2010 | HP DesignJet 120nr InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP designjet 120nr printer driver problem
I haven't made it thet far. I cannot find a driver for PC.
Feb 21, 2009 | HP DesignJet 120nr InkJet Printer
Uninstall and reinstall the driver/software.
Feb 20, 2009 | HP DesignJet 120nr InkJet Printer
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP DesignJet 120nr InkJet Printer Logo
134 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
