Recently, my transfer case went out. An now theres a clicking noise from the driveshaft, I'm thinking universal joints or some bearing in the drivetrain. Because I didnt fix the transfer case yet would that be the reason why I'm having this problem now?
    Problem Solver:
  • 10 Answers
Not really but you could have metal lose in the transfer case you really need to fix that it could sieze up and get much worse
Posted on Jun 16, 2009
Loud roaring, metal on metal noise coming from
have you checked the fluid in your front differential yet? joints on the front driveshaft from the transfer case?
Aug 05, 2017 | Cars & Trucks
I have an 07 gmc sierra 3500 hd. I get a vibration in the floor only when Im in four high and aplying power. Nothing in two wheel drive. My local dealer changed all my u joints my front drive shaft, cv...
MOTOR MOUNTS ? TRANS MOUNTS ? BOLTS LOOSE ? SOMETIMES WE FORGET TO TIGHTEN THINGS , IT HAPPENS TO THOSE IN A HURRY !!! TRANSFER CASE COULD BE SUSPECT ? SEALS, BEARINGS, ETC., SURE DRIVESHAFT IS BALANCED, CORRECT LENGTH ? UNIVERSAL JOINTS TIGHT ENOUGH, MISSING BEARINGS FROM THEM, MADE IN JAPAN, MEXICO. MOOG/USA IS ONLY WAY TO FLY !!!!!!!!!!!!!!!!! MADE IN USA !!!!!!!!!
Mar 24, 2013 | 2006 GMC Sierra
Transfer case driveshaft is loose and clanks around, is there a support bearing that broke off or is it something else?
universal joints, you had better watch out if you dont get that replaced soon it will come loose while you are driving causing serious damage
Sep 19, 2010 | 1999 Dodge Durango
I have a roaring noise under the hood of my 06 chevy Z71
Have you looked at the Universal joint(s)? If it is 4-wd I'd inspect the front driveshafts as well - Other than that, I'd also inspect the brakes to ensure that the shoes were being held down properly and that the Universal joint is not worn - It sounds alot like either the U-joint or a brake problem - Have you inspected the rear end? Do you use the truck to pull anything? If you'll look at the U-joint and Brakes - If not, there are carrier bearings inside the rear end that may be the culprit as well, but I'd leave them for last as inspection is a bit involved -
Aug 30, 2009 | 1999 Chevrolet Silverado 1500
Whining/grinding noise at deceleration
We have the same problem at our shop. We haven't rebuilt the front differential yet. We tried 3 different shafts on 2 different Jeeps and the noise is on both just the same. By greasing the front driveshaft cv joint, we got he noise to quiet some, but it is still way to loud. With the driveshaft out, the noise is gone. We are about to buy a new shaft from the dealer for $600. There are some service bulletins about some noisy driveshafts.
Jun 15, 2009 | 2009 Jeep Grand Cherokee
Part names
cardan centering bearing
point bolts needed to be removed that connects D.S.to transfercase
May 22, 2009 | 2001 Ford Excursion
Rear end noise
You cannot check universal joints with the driveshaft under tension. Trans needs to be in neutral (wheels blocked or on jackstands)
If diff is noisy, check gears by removing cover and checking lube for metal debris, gears for "sharpening" on edges. Generally it is cheaper to replace unit with one from a scrapyard. Any work regarding bearings or gears requires precise depth and lash adjustment or the unit will quickly fail again.
Universal joint failure will cause a "clunk" when engaging reverse or drive and also can cause vibration similar to out of balance tires. Worst case is a rhythmic squeak while going about 10-20mph.
May 10, 2009 | 1999 Chevrolet Astro
Banging noise in 4 wheel drive under torque. front hub questions.
Hello scotch1812, those of us that still enjoy the square headlights have to stick together! The front axle in our YJ's are dana 30 with a high pinion! The high pinion make the ring and pinion spin in a reverse rotation from the dana 30 found in CJ and TJ Jeeps. When Chrysler designed the YJ front axle, they removed the manual hubs like those found in CJ models and installed a vacuum disconnect on the passenger side axle shaft. The passenger side axle shaft is 2 piece with a sleeve that is moved into place to connect the 2 pieces of axle shaft when you shift the transfer case into 4 wheel drive. This is done via a vacuum module mounted on the axle housing. If your module diaphram goes bad you have no 4WD! If your vacuum hose comes off of the module or breaks you have no 4WD. Now when your transfer case is in 2WD the front driveshaft does not turn. The vacuum disconnect allows this to happen. As for the hubs, they are simply hubs with sealed bearings and a universal joint to allow your front wheels to turn left and right. If you hear the banging noise in 2WD it could be a bad universal joint in one of your axle shafts.
Now if you are hearing the banging noise only when you are in 4WD there could be a number of reasons. You could have a broken axle shaft or a bad bearing in your ring and pinion. Your front driveshaft could be bent or at least not straight. I would start with the driveshaft. Just lay under the Jeep (Not running! With emergency brake set!) and spin the front driveshaft. If it spins true and doesn't have an out of round rotation we can rule that out! Also, grab it and push it and pull it to check to see if your universal joints in the drive shaft are gor and tight! They can make a grinding noise or popping noise if they are bad!
Try these and let me know what you find! We will find your problem!
map6260
Mar 13, 2009 | 1992 Jeep Wrangler
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
