Question about Evenflo Generations
How to convert Pooh Days of Hunny Activity Center Exersaucer
I have the Disney Pooh Days of Hunny Activity Center Exersaucer. And it converts to a toddler play table. But of course I threw away the directions months ago. I want to switch it but don't know how. Does anyone else have this??????
Ok take the legs off of the top part (white) just twist and the top part comes off; then twist the springs off. Now take the legs that you took off and slide them through the first hole of the bottom from the bottom not the top; do all three legs and you have a table.
You can pop off the toys the tigger and flower one you have to push the thing till you have a big enough for it to slide through.
The disney pooh car pops right off of the top part; then you just unscrew the car from it's bottom (2 screws) take it off the track and volia you have a car.
I bought mine from someone but with a little bit of imagination I figured it on my own. lol.
Posted on Aug 04, 2009
Which holes do the legs go back into? The green, bottom piece or the white top piece? Or can it only be a table for one side of it?
It turns into a figure 8 shape track if you use both the pieces on the floor. I'm pretty sure this is the same one you have, but I got mine from Big Lots for $40, so it could be irregular. I know it seems like Rabbit is on his perch backwards, facing outside the circle instead of in towards the baby and I thought that was the only defect. It was in an unopened box and was brand new though.
Posted on Aug 20, 2009
Convertexersaucer to activity table
Here's an article along with photos and video on converting the Evenflo Exersaucer to the activity table: How to Convert the Evenflo Exersaucer into Stage 3
Apr 08, 2015 | Evenflo Exersaucer Triple Fun Active...
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
How to I convert my exersaucer into an activity table
Here's an article that explains how to convert the Evenflo exersaucer into the stage 3 activity table. It has photos and videos to help explain the process. How to Convert the Evenflo Exersaucer into Stage 3
Feb 23, 2015 | Evenflo Toys
How do I convert exersaucer to activity table
Here's an article explaining how to covert the Evenflo exersaucer into the stage 3 activity table. How to Convert the Evenflo Exersaucer into Stage 3
Sep 01, 2014 | Evenflo Exersaucer Triple Fun Active...
I can not disconnect the legs from the exersaucer to convert it into an activity table
Here's a detailed article that explains how to disconnect the legs from the exersaucer to convert it into the stage 3 activity table. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 20, 2014 | Evenflo Exersaucer Triple Fun Active...
I need to fold the evenflo exersaucer to store it
Unfortunately, folding it to store is not a simple task. You'll have to remove the base which will allow you to fold the legs. Although the article I'm referring you to is for converting the exersaucer into a stage 3 activity table, it does give instructions on how to remove the base which will allow the legs to fold. How to Convert the Evenflo Exersaucer into Stage 3
Feb 05, 2014 | Evenflo Exersaucer Triple Fun Active...
How to convert To stage 3
Here's an article on how to convert the Evenflo Exersaucer to the stage 3 activity table: How to Convert the Evenflo Exersaucer into Stage 3
Jan 16, 2014 | Evenflo Exersaucer Triple Fun Active...
How do i convert it into the s shape activity center
hi here are the instructions
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 28, 2010 | Evenflo Exersaucer Triple Fun Active...
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Evenflo Generations Logo
867 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
