Question about Xerox Phaser 8500/DN Printer
I am getting a paper jam error whenever I power up. I believe it is a sensor issue, but I am not finding any flag sensors except under screen, which I believe goes witih the front door. Where can I find to likely bad sensor and how do I get to it. Thanks David Nelson
  • 1 more comment
  • David Nelson Jun 17, 2009
    Thanks, but it sis not sole it for me.
  • David Nelson Jun 20, 2009
    Too bad I did not read this before I took the side cover and front end off! That apears to be what the issue was.
    I checked sensors for voltage switch.On the feed path in fromt the yellow wire gives a .6v switch. It may be a current device. On the paper present flag on the red wire there is a 2.9v switch. On the Safety interlock switches the violet wire J610 gives a 2.9v switch the white wire also gives that when activated.
    The J connectors are located on io board under the right side cover.
    Cleaning the rubber wheels seemed to fix it. Thanks
  • 27 Answers
If you are getting a "jam in front cover" when you try to start your printer but you don't see any paper in the paper path, try cleaning the pick roller that is above the paper tray. There is a lever/switch next to the roller assembly that will cause the RA to swing down then you can pull it straight down and remove it for cleaning. watch how it comes out so that you can get it back in properly. The roller should not be shiny and should have a "marble/snake skin" texture. If it has no more texture or it is shiny, it should be replaced.
after cleaning/replacing the roller reinstall the roller and test the unit.
Posted on Jun 18, 2009
    Sergeant:
  • 361 Answers
I am agree in your opinion.Becuse senser attach mainly in cover and paper fedder of computer .we had solved that of problem in this waysome time in our lab. we open covere of printer and blow air by blower in everywhere in printer and after adjust cover. i hope you can solve this problem
Posted on Jun 16, 2009
How do I fix paper jam for AV122C
Sounds like the machine is picking up a signal from the paper exit sensor. The flag is not moving freely, or not moving at all. Look down in the paper hopper, ( where the paper is loaded), you might be able to see the sensor. The flag is spring loaded. Sometimes the flag falls off. The flag is black and shaped like a (T).
May 11, 2014 | Avision AV122 Color Duplex 18ppm/36ipm CCD...
Piece of garbage jammed again, removed the jammed paper and am still getting error that it has a jam in cartridge area. I have taken out the cart. and blown it out with air and also took the back off and...
Hello denelson994,
Welcome, and thank you for using FixYa!
Your issue has to do with the paper sensor flags just under where the cartridge is inserted.
If there is paper or dust in that sensor(s), the printer will interpret that as a paper jam. Grab some canned air, blow everything out, and then physically examine those sensors under the cartridge area.
If the sensors were dirty, they should work now. If the "Flag" (plastic lever) that is pushed down as paper passes over it, is broken off; the sensor(s) will have to be replaced.
Make sure you flip up or back, any metal plates you can, to look for paper shreds or dust under them as well.
Have a great day!
Sep 12, 2011 | Dell 1815dn All-In-One Laser Printer
HAVING A 13.20.00 ERROR CODE ON A HP 43OO. PLEASE HELP!!
JAM IN TOP COVER AREA
A jam exists in the top-cover area.
A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned
for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel
display after you replace the paper feed assembly, verify that this sensor-flag spring is installed
correctly.
Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the
chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring
from the tab on the flag (see 2 in Figure). See figure below.
Verify that the flag is held in the upright position, can freely move, and always returns to the upright
position. If the flag does not move freely, or return to the upright position, an error
message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned
on.
Aug 10, 2011 | Office Equipment & Supplies
Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Jan 04, 2010 | Samsung ML-3051N Laser Printer
Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Aug 10, 2009 | HP LaserJet 5200tn Printer
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Nov 06, 2008 | HP DeskJet 3930 InkJet Printer
Paperless paper jam
Ok, the paper jam ERROR could be due to one of the following:
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced or repaired under warranty.
Hope that helps!
Sep 12, 2008 | Lexmark E320 Laser Printer
PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Jun 05, 2008 | Lexmark E342n Laser Printer
Xerox Phaser  8500/DN Printer Logo
153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
