Question about Solis Crema SL-70 Espresso Machine
Trouble installing replcement gasket in Solis Crema SL 70
How do I take the machine apart in
order to replace the gasket?
  • 1,089 Answers
SL 70/90 Brew Head Gasket Replacement Time 1 to 2 hrs Tools # 2 allen wrench # 1 Phillips screw driver # 2 Phillips screw driver # 13mm wrench First unplug the machine. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 allen screw. Loosen this screw and the rotate the steam knob clockwise until it is removed. Now remove the clip on the steam manifold that holds the steam wand. There may be a plastic tie that is securing the clip. Cut it. Pull out the steam wand and let it rest on the bottom cover. Next remove the 4 large screws that hold the cover plate around the brew head. This will allow the cover plate to drop down and swivel on the steam wand, exposing the nuts that hold the boiler on the bottom metal plate. The nuts that hold the boiler on are # 8. Before you loosen the nuts you need to remove the water inlet nut on the side of the boiler. It is a #13 wrench. Remove the water line. Now remove the nuts that hold the boiler on.
Posted on Jun 16, 2009
How do i replace a gasket
once you have the machine apart carefully scrape any old gasket from both surfaces. install new gasket and torque bolts to specs
Oct 17, 2014 | Garden
Miele w4840 door rubber seal relacement
i just replaced rubber gasket on miele w4840 it took lots of patience! there is a retaining wire on spring on front part this is easily removed. next there is a light and water line about 11 o'clock take this apart and unhook water line in order to remove these from gasket. next there is a locking wire on right side at 9 o'clock. i was able to get a flat head screwdriver and loosen the screw you can open about 1 -1.5 inch at this point the rubber seal can be removed. you have to carefully (painstakingly) put the new seal on. make sure everything is lined up right before replacing the wires took me about an hour as the gasket is difficult to put on back part on drum
Apr 16, 2012 | Miele W4840 Front Load Washer
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Do i need to take apart the machine to replace the gasket
the gasket you mean is the one upper to the filter I suppose...bring to service if the gasquet is not well inserted can cause a lost of pressure or even explosion!
Jun 03, 2010 | Ariete Cafe Retro Espresso Machine
How to take apart the straight six without destroying anything
4.0 L engine is likely the last easy engine to work on. Get a haynes or chilton manual and follow the directions. In order not to destroy anything, that lies with you. Use care, don't force anything and use the proper tools.
As far as "taking apart" , some items such as the crankshaft are not removable without taking the engine out. A carefully torn down engine should need no more than replacement of worn or damaged parts and a gasket set (plus machine work where necessary)
Any questions about a specific component can easily be answered by anyone here.
May 24, 2010 | 1994 Jeep Cherokee Country
Looks like rubber gasket at bottom of blender container is coming apart. How can I order a replacement or do I have to order the complete container?
you might have to order a new container, because i have not been able to find individual parts for sale. however, you might try and call the manufacturer, because sometimes you can order replacement parts.
Nov 21, 2009 | K-Tec Champ HP3 Work Top Blender
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
SL 90 Machine not heating
Hi There are 3 things that could be the problem. 1. The power board on the left rear inside. 2. Heating element is burnt out. Replace the top part of the boiler and order a brew head gasket and replace it at the same time while you have the machine apart. 3. and less likely is the temperature sensor. 2 red wires goes from the board to the top of the boiler.
Nov 16, 2008 | Solis Crema SL-90 Espresso Machine
Solis Crema SL-70 Espresso Machine Logo
956 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
