Need instruction on how to fax using controls on HP 5610 printer - paper feeder jams so not sure where to put paper and data facing up or down?
    Scholar:
  • 124 Answers
Posted on Jun 16, 2009
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Cartrige won't move
Instructions Things You'll Need:
  • Cup of distilled water
  • Clean wash cloth
    Fixing The Printer Cartridge
  1. Shut down the HP 6480 by pressing the "On/Off" button on the right side of the control panel. Some paper jams will clear themselves just by turning the printer off and starting it again. Wait a few minutes after the printer has shut down and then turn it on again.
  2. Remove the paper feed tray. If the printer does not clear the paper jam by itself, shut off the device again. Be sure to pull the tray out gently to avoid damaging the device.
  3. Lift up the automatic document feeder. The feeder makes up the top half of printer, and it can be opened like the hood of a car. Lift the sides of it slowly. This exposes the printer mechanism and ink cartridges. Pull the jammed paper up and out of the printer mechanism with both hands. Pull it gently to ensure you don't damage any components.
  4. After removing the paper, clean off the cylindrical, silver printer roller. Dampen a clean cloth with distilled water, and gently wipe any dirt, ink or paper off the roller. Rotate it when you're done cleaning one side, and continue rotating and cleaning until the roller is clean on all sides.
  5. Close the automatic printer feeder. After removing all paper, close the top printer feeder and shake it to ensure it's fastened. Re-attach the printer tray by lining it up with the arrow markers on both sides of the printer.
  6. Put one sheet of paper into the printer tray, and reset the HP 6480 by pressing and holding the "On/Off" button for 15 seconds. The printer should automatically restart and return to factory settings. It will run diagnostics and the printer cartridges should begin moving again as they print a test sheet.
Dec 21, 2010 | HP PSC 1350 All-In-One Thermal Printer
How do u put the print paper in facing up or facing down printer photosmart c4750
If ordinary paper it does not matter.If photo paper then put it in the feeder tray glossy side down and one sheet at a time as glossy paper tends to stick and causes paper jams.
May 04, 2010 | HP Office Equipment & Supplies
Faxing instructions do you insert paper face up or face down
If you're putting it on the glass, it goes face down. If you're talking document feeder, look for the icon of a page. It will show printing with a corner curled (face up), or a blank page with lines on the curled part (face down).
For an example of what a face up icon looks like, check out the HP instructions for an HP machine here http://h10032.www1.hp.com/ctg/Manual/c01325508.pdf
That's the generic answer to a non-listed model number :-)
Carl
Feb 23, 2010 | HP Office Equipment & Supplies
Loading the paper in the fax on a 6480 all in one. Does the printing face up?
Faxes are sent print facing down. If you look closely on the plastic part where you put paper it shows you kinda folded paper showing print is down. Hope this helps.
Jan 27, 2010 | HP Officejet 5610 All-In-One InkJet...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Which way does the paper go into the feed when faxing?
Load the originals, with the print side up, into the document feeder tray. If you are sending a single-page fax, such as a photograph, you can also load the original on the glass. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax
Face up if using the feeder. Face down if scanning on the glass.
Aug 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
